Fuel Taps
frankfast
Re: Fuel Taps
That would work but would require two different size fuel lines and four more clamps, all potential leaking points. I know a more expensive but simpler solution would be to change the taps at the tank. Shipping from the EU to the states may be a problem during the current pandemic. I'm currently waiting for a box of Cubans from Spain.
Re: Fuel Taps
Hi Aaron
tanks where made by Tebaldi
amartina75 wrote:Keep in mid Ducati didn’t make any of those parts, they sourced what was available from Italian companies at the time. Even the gas tanks were outsourced as far as I know. Don’t remember who produced them but I’ve seen pictures of a makers mark inside gas tanks.
Also parts are swapped over time with whatever works and is available.
I think what Jordan is pointing out is that the tolerance between parts were pretty loose.
blaat!
Re: Fuel Taps
Speaking of Tebaldi, I just noticed this stamp inside my tank:
Looks like it says FLL TEBALDI MONZA
Don't judge my oxidation
Re: Fuel Taps
Wow, that's impressive observation, there!
. Thanks for the post.
Remind me, this is a Mach 1, yes?
Ciao
Craig
('Fll' is Fratelli, of course)
Ciao
Craig
blaat!
Re: Fuel Taps
Good memory Craig! It is a Mach 1. The only reason I noticed the stamp was that I'm currently removing the rust inside.
Re: Fuel Taps
blaat! wrote:Good memory Craig! It is a Mach 1.
Ta - thanks for the confirmation.
Users browsing this forum: No registered users and 86 guests
