Swing Arm Bushes
Re: Swing Arm Bushes
Postby Duccout » Thu Nov 26, 2020 7:02 pm
Hi Kabi,
The pin looks quite corroded and so do the bushes, from what I can see. Is there any damage or burring at the ends of the pin? You could run around each end with a file to be sure, and clean up the pin with some emery cloth. A new pin may be a good idea, but obviously that is more cost.
Kabi
Postby Kabi » Sat Nov 28, 2020 5:29 pm
The pin seems to be ok on both ends, no damage etc. Maybe the sand paper will help.
But i'll check the link on top, about the bushing..
Kabi
Postby Duccout » Mon Nov 30, 2020 4:50 pm
Kabi, are the bushes and the pin the ones that were fitted to the bike? I ask because if they fitted together originally, then they should fit again!
Kabi
Postby Kabi » Sat Dec 05, 2020 9:44 pm
Duccout wrote:Kabi, are the bushes and the pin the ones that were fitted to the bike? I ask because if they fitted together originally, then they should fit again!
im sorry for late answer.
Yep, they are the same. I dismantled it, clean the pin and bushes. But, if i remember correctly, the movement was not smooth before :idea:
Hard to say if someone did something with it before, or it is "dead" thanks to age :?:
What i can try is to sandpaper the pin properly, polish it, lube well with vaseline and will see if i will be able to hammer it back 8-)
Maybe i give a try to old hack i know from Jawa - put the pin to the fridge :) it helped sometimes.
What do you thing?
Kabi
Postby Jordan » Sun Dec 06, 2020 11:05 am
If it is needed to make the movement easier, give more clearance.
But rather than making the steel pin smaller, you can make the bronze bushes larger.
A way to do this, if it is only a small amount, is to use a brake cylinder hone tool in a hand held drill.
Use kerosene or similar to lubricate when using it, and wash well before assembly to remove debris.
https://www.ebay.co.uk/c/1764181966
Postby Duccout » Sun Dec 06, 2020 3:45 pm
Yes, my thoughts too. By hammering the pin in you may create ridges or burrs that make it harder to get the pin in. You could try a new pin, but if you do not wish to risk buying one that may not fit either, what about taking the pin and swinging arm to a small engineering company and ask them to gently ream the bushes out until the pin fits?
Kabi
Postby Kabi » Sun Dec 06, 2020 6:41 pm
well, both of it sounds good to me. Tomorrow i'll check how the bushing and pin look in detail (my memory is weak), i'll try to post a foto for analysis.
thank you guys :!:
Kabi
Geordie
Postby Geordie » Mon Dec 07, 2020 5:47 pm
If the pin moves freely in one bush at a time but is stiff in two then they are misaligned.
Kabi
Postby Kabi » Mon Dec 07, 2020 6:21 pm
Hey guys,
i made a few photos, posting it with note. hope it will show.
But now, i was thinking, how it work properly? Does the pin should be stiff/fixed in swingarm and move almost freely in frame? It sound logic to me, that pin is fixed in only one bushing (frame or swingarm).
Unfortunately, i'll be in garage tomorrow morning to check how the pin fit into frame bushing - i remeber badly, it is something similar to swingarm ~ stiff.
Geordie: i know. The main issue is, swingarm is stiff when i insert the pin. It was before i disasembly frame x swingarm.
Kabi
Postby Duccout » Mon Dec 07, 2020 7:18 pm
Hi Kabi,
the pin should slide freely through both bushings in the swinging arm, and is then clamped firmly in the frame so that the swinging arm pivots on the pin. It does not matter if the pin is stiff in the frame ( that is preferable to being loose). What Geordie says is a worry - if the pin slides easily into each bush but not both of them, then there is a possibility that the swinging arm pivot is bent and the two bushes are out of line, or the pin is bent. Are there any signs that the bike has been in a crash?
The bushes look good and you can check the straightness of the pin by rolling it on a flat surface. Check to see if the pin will slide easily through both bushes in the swinging arm, then take it out again and see if it will slide through both clamps in the frame without fitting the swinging arm. Have a look tomorrow and let us know what you find.
Users browsing this forum: Google [Bot] and 197 guests
