1974 Mk111 450
weggy96
Re: 1974 Mk111 450
Postby weggy96 » Tue Jun 16, 2020 3:13 pm
Hi All
As suggested I tried a bump start and it fired up and ran so now I know it’s the ignition so will start looking for substitutes
Thanks everyone
Weggy
Re: 1974 Mk111 450
Postby Ventodue » Tue Jun 16, 2020 4:43 pm
Weggy, before you go too far in shelling out the folding stuff ...
Just describe for us your kick starting technique. You do have a decompressor/valve lifter fitted, yes?
Re: 1974 Mk111 450
Postby blethermaskite » Tue Jun 16, 2020 5:04 pm
Now you have had it running again, did you try to start it on the kickstart when it was hot? did it start easy on the bump start?
weggy96
Re: 1974 Mk111 450
Postby weggy96 » Wed Jun 17, 2020 10:50 am
Good news after the bump start it kick started with no problem and I gave it a good run and all Ok.
I kick started it this morning from cold and it fired up and ran on the second kick carb flooded no choke and a couple of kicks with the valve lifter.
It looks as if the problem is solved for now so thanks to you all for your advice.
Weggy
Re: 1974 Mk111 450
Postby blethermaskite » Wed Jun 17, 2020 12:35 pm
That's great! but I suspect a little warning of something to come, it would be a good idea to start looking now (at your leisure) for a replacement ignition system.
weggy96
Re: 1974 Mk111 450
Postby weggy96 » Wed Jun 17, 2020 1:50 pm
Hi George
I am sure you are right so I am looking around on various websites for a replacement system or convert to points & coil
Thanks again
David
Re: 1974 Mk111 450
Postby Jordan » Wed Jun 17, 2020 10:28 pm
Maybe both points and electronic?
It's an economical way to do it, if you already have the points bits, which I think are pretty good mechanical quality.
It could give the electronic advantage of easier starting.
http://gammatronix.com/
Users browsing this forum: Majestic-12 [Bot] and 87 guests
