" so I thought I would take a picture of the Amal 930 bolted directly to the head. "
____ Thanks for that pic, Pete!
I had been looking for any picture much the same as that, to add to this thread (and now I no longer need to)!
____ Concerning another topic about fuel leaking down into the oil-sump... When the carb is mounted at a forward-angle like that, then ALL the leaking-fuel goes down into the engine, rather than some portion flowing backward to soak into the air-filter.
Of course both ways are to be avoided !
____ So Pete, what's the story on your cyl.head's compression-release area no longer being as stock, (as can be noted in your pic) ?
Amal on my 450
Re: Amal on my 450
Pete
Re: Amal on my 450
That's the way I bought it. It doesn't seem to be a problem and I really don't want to pull out the plug for fear of what I might find. The gas tank had one of the petcocks replaced with a 1/2" bolt!
Pete
MotoMike
Re: Amal on my 450
Pete
I am not seeing what you guys are talking about. can you explain?
Pete
Re: Amal on my 450
Hi Mike,
It is a little off topic, but the compression release on my 350 lives in a hole in the head. It looks like a spot for another spark plug. You can see it behind the left side of the oil return line. My particular engine has the compression release removed and the hole plugged with a socket head screw. I hope the picture of the Amal was helpful to you.
Pete
Pete
MotoMike
Re: Amal on my 450
Pete wrote:Hi Mike,
Pete
hi Pete.
Yep, I see now that the 900 series can definately fit right on the head.
I was not aware of the compression release of the type you have. Mine was on top of the valve cover. thanks.
Mike
Re: Amal on my 450
The compression release was fitted into the cylinder head near the oil drain tube on some Spanish built 350 engines, notably the 350 Road.
It was similar to that fitted to the 450R/T although I think that the thread was different.
The 450R/T decompressor used a 10x1 thread, whereas the Spanish Road models used a 10x1.25 thread. (I stand to be corrected if someone knows better)
Strangely, the Spanish built 350 motors supplied to Bologna for fitting into the late 350 Mark 3's were fitted with the decompressor on the rocker cover, just like the Italian engines.
Re: Amal on my 450
" It looks like a spot for another spark plug. You can see it behind the left side of the oil return line. "
____ It was that oil-line that was most noticeably out-of-place on that 350-model !
I could not currently come-up with a pic of the 'Road' model but I am posting a pic of a 'R/T' model, showing the same type of set-up.
__ While the R/T has the same threads as a 10mm spark-plug, the compression-release on the Mototrans-head unfortunately uses the coarser (more common) metric-thread.
____ Pete, how long have you owned that 350-Road of yours?
Cuz I have some three year old pix of another 350-Road (of someone's) which also has those stock parts replaced, just like yours, (which is unusual!). _ So maybe either we've made contact before or I got the pix by a previous owner.
DUKE-Cheers,
DUKE-Cheers,
Re: Amal on my 450
Looks like you have a fuel leak mike.
MotoMike
Re: Amal on my 450
Bevel bob wrote:Looks like you have a fuel leak mike.
are you looking at my mine or another?
MotoMike
Re: Amal on my 450
DewCatTea-Bob wrote:____ In any case, the alignment-matching of all the intake-tract's port-mouths, ought to be checked-out anyhow, (to see if that unstock set-up was done by someone who actually cared about doing it well).
Happy-Cheers,
Well I pulled the 932 as the rebuild kit has arrived from Burlen Fuel. I checked the bore in the carb and it is in face 32mm. the manifold shows signs of someone hand working it into bell to match the carb. The manifold inlet where it mates with the carb is right near 32mm. Don't know what it was originally. the modification is all done in the first 3/8 inch or so so the change is fairly steep but smooth. I reached into the manifold to feel the joints over the vibration isolator and into the head's port it is pretty smooth as well. no steps.
Users browsing this forum: Google [Bot] and 71 guests
