thanks for looking
Mike
Teckhardt wrote:
At the end of the day, unless you are going for a restoration, who cares. (Sure I will get flamed for that) Build it the way you like it.
DewCatTea-Bob wrote:" the frame has ears welded to it that seem original that the boxes seem to mate with properly.
the USA model on page 6 have my tank and what I think are the same tool boxes.
Of course these all have the rear loop of the frame straight and mine is clearly upturned.
the tall loop that the scramblers have is not present on mine. "
____ It now seems to me that you have something unfamiliar to me which likely has been altered from the usual 450-production models that were imported to the USA.
While none of the DUCATI-dealer/shops that I worked at ever got-in any 450-model like yours, I have heard tale that towards the end of the 1970 production-year, Ducati made a few 450s with left-over production-line parts from both the Mk3 & SCR lines. _ Although until now, I never had any good reason to believe that tale.
And now that I really think of it, I do believe that (sometime in the distant-past), I have seen pix of (then new?) 450-models like yours (with std.Mk3-seat too, I think), but had then assumed that such had been made for the Canadian or Brit-market, or somewhere else other than here in the U.S.
__ What is the motor-number on yours? _ If it's older than my 1970-450, then I'd believe that yours was put-together with mixed parts that way, by somebody,, but if it's newer, then I might consider believing that tale about such factory-made 'mixed-parts models'.
____ BTW, could you please provide any well-lit close-up pix of the carb & cyl.head area of your 450? _ As I'd much like to see that carb & plumbing set-up you have, a lot better !
DUKE-Cheers,
