GM Desmo Camshaft
GM Desmo Camshaft
Postby double diamond » Fri Dec 28, 2018 4:25 am
I have a 350 desmo head on the bench that I’m checking over. That cam is marked “GM”. GioCaMoto?
Ducadini
Re: GM Desmo Camshaft
Postby Ducadini » Sat Dec 29, 2018 8:41 am
Giorgio's goods were marked GM but I never saw any cams for the singles .
Now it is possible to fit a bevel camshaft in a single head but that involves opening the gap where the support is (LH side) a few mm.
Easy to check.
ciao
ducadini
Postby Eldert » Sat Dec 29, 2018 8:52 am
GM made Desmo single camshafts for sure . mine has GM and DR stamped on it
i would like to know where the DR stands for . Desmo Racing would be to obvious .
Postby double diamond » Tue Jan 08, 2019 7:25 pm
Apparently, fitting this cam required opening up the cam bore in the head. Whomever did the machining went a little too far and had to weld up the hole for the head bolt.
This head also has a modification to the valve guide. A short guide, something like a Pantah arrangement is installed (I've removed the valve guide oil seal and the Pantah type closing spring in the pic). The underside of the forked closing rocker is relieved to clear the valve guide oil seal.
Users browsing this forum: No registered users and 125 guests
