Mototrans VIN
Mototrans VIN
Postby ducwiz » Sun Mar 25, 2018 11:15 am
Dear all,
as the Mototrans forum part is locked for whatever reason, let me post some helpful information about Mototrans models and their chassis numbers/identifiction codes/year of mfg. right here:
http://www.lamaneta.org/numerochasis/ducati.html
Re: Mototrans VIN
Postby Ventodue » Sun Mar 25, 2018 5:47 pm
Thanks, Hans!
Craig
Re: Mototrans VIN
Postby Jon Pegler » Thu Mar 29, 2018 3:36 pm
That list is one of the most accurate for Mototrans machines, although even then one has to be careful as there are a few mistakes.
The Forza and Vento went into production in February and March 1977, not 1976 as stated.
Also, for some reason the 200TS numbers started at 61851 according to Mototrans technical circular number 23.
Why not at 60000? I have no idea, unless the 175 numbers went over 60000, although I've only seen 175TS numbers go up to about 58000.
If anyone knows differently, I would like to hear from them to help with my notes.
Site Admin
Re: Mototrans VIN
Postby JimF » Fri Mar 30, 2018 2:30 am
The Mototrans section was closed so as to bring Mototrans posts into this main discussion group.
A big concern was that posts in the Mototrans section would not get enough views to illicit replies being as it was separated from Italian-made Ducatis and required more effort and time from members to review.
The commonality of these two closely related motorcycles far outweighs any minor differences they have.
Closing the Mototrans section was not meant to be a slight to Mototrans owners but rather it was intended to better support and celebrate the Mototrans Ducatis and their descendants developed after Italian Ducati singles ceased production.
Jeb
Re: Mototrans VIN
Postby Jeb » Thu Apr 05, 2018 8:59 am
So. My Mototrans 250 NC 5 speed which I was told is a scrambler has eng no MD933## and frame no MD934## and should be a 250 Deluxe from that list. Is that correct or am I missing something ?
John
Re: Mototrans VIN
Postby Ventodue » Fri Apr 06, 2018 8:28 am
Jeb wrote:So, my Mototrans 250 NC 5 speed which I was told is a scrambler has eng no MD933## and frame no MD934## and should be a 250 Deluxe from that list. Is that correct or am I missing something ?
Pretty sure, John, that no Mototrans narrow-case ever carried the Scrambler name. Bologna, however, did make one between 1965-67; but these would have carried DM frame and engine numbers.
The first (and only) Barcelona 'Scramblers' were wide-cases. (In fact, all the later 'Italian' 250 wide-case Scramblers were assembled In Bologna using Spanish-sourced parts. And all the 350 Scramblers had Spanish-sourced engines).
So, bearing in mind that the 250 Deluxe was the best selling machine in Spain (source: Carlos Polo, Ducati Mototrans), I reckon that's what yours is/was :) .
Un saludo
Craig
Re: Mototrans VIN
Postby Jon Pegler » Sun Apr 08, 2018 3:13 pm
The late 250 De Luxe models changed in appearance from the photos Craig has posted, and did look more like a narrowcase scrambler.
A number of parts from the narrowcase 250 Road were fitted, including the tank and seat.
Some even had the small triangular toolboxes of the 24 Horas/ Mach 1 etc..
As Craig says, the only true Scrambler models made by Mototrans were 250 and 350 widecase machines, but even these had different frame number series depending on whether the machines were for Spanish home use or export.
I would say that Jebs numbers indicate a 250 De Luxe from the early 1970s.
Post a photo.
Jeb
Re: Mototrans VIN
Postby Jeb » Tue Apr 10, 2018 4:57 pm
[attachment=0
]Ducati 250 003.jpg[/attachment]
Pictures of the Ducati as it was when brought.
Re: Mototrans VIN
Postby ducwiz » Tue Apr 10, 2018 7:03 pm
Presumably a 1972 250 Road:
1973 250 De Luxe and Road:
1974 250 De Luxe and Road:
1975/76 250 and 350 Road:
And more useful links (in french or spanish):
http://www.ducati-sud-belgio.be/desmodrome/?p=629
http://perso.wanadoo.es/kombo/modelos.htm
Finally, a large site with a vast amount of fotos, showing resoration work on a 350 Road (w/c, spanish). Beware, it takes a very long time to load ...
https://moticosroyo.wordpress.com/category/ducati-road-350/
Re: Mototrans VIN
Postby Jon Pegler » Tue Apr 10, 2018 11:18 pm
Not a 250 Road, but a 1974 250 De Luxe, 5 speed .
As I said before, the late 250 De Luxe incorporated a number of parts from the 250 Road, hence the tank and seat .
The Spanish registration is a 1974 Valencia number.
