Hoping the knowledgeable folks here can help with my carb issue. I have been rebuilding a 1969 350 SCR that I purchased a few years back. After a long sleep of probably 20 years it roared to life today. But I need some help with the carburetion. The original carb was missing so I purchased a new Dellorto PHBH26. The bike is running very rich, idling for a while but very rough and lumpy above idle. Not sure about the high RPMs.The plug is black, sooty but backing out the air mixture screw does not help. I also moved the needle clip up a notch which I believe leans out the mixture but no appreciable difference was noticed. Anyway I am excited to get it running but have not enough knowledge of carburetors. The carb was supplied with the following parts:
40 slide,X6 needle,268T atomizer, 120 main jet, 50 idle jet.
Carb novice requests help
Re: Carb novice requests help
Looking at the jetting you have got in your carb, I would say that the atomiser is very big, which would cause richness.
I would think a 262 or a 264 would be a better size.
The rest of the jets look to be a reasonable starting point.
Are you sure that screwing the mixture screw out is not richnening up things too?
The Dellorto PH carbs do not have a pilot air screw like an Amal carb, that admits more air, but a mixture screw that admits a fuel/air mixture.
(Apart from the very first models), The standard Dell'Orto carb for the 350 SCR was a VHB29. So yours is neither the 'right' size nor the 'right' type
. Which risks making things a little more complicated ...
FWIW, the spec for the VHB carb was:
Atomizer: 265M
Mains: 110
Idle: 45
Needle: V13
Slide: 50.
(Source: owners h/book and factory parts manual).
How these specs might change for a smaller PH carb, I can't say. Somebody at Eurocarbs might - ?
But, if it's faulting on transition, as Jon says: first suspect the atomizer and/or the needle.
Atomizer: 265M
Mains: 110
Idle: 45
Needle: V13
Slide: 50.
gmlaverda
Thanks for the input gentlemen. Regarding the mixture screw, it does idle better and at a higher RPM with the screw completely turned in. But the throttle response is still the same as before.
Above idle, the system that comes into affect next is the the slide cutaway.
The smaller it is, the richer. Yours is #40.
For a 250 with PHB carb, these settings were suggested by Phil Hitchcock of Road & Race:
#60 slide, #60 idle jet, #265 needle jet, K5 needle, and 114 -118 main jet.
If the PHB is a pumper, disable the pump by removing the lever pinned to the carb top.
Jordan wrote:Above idle, the system that comes into affect next is the the slide cutaway. The smaller it is, the richer. Yours is #40. <snip>
Good point, Jordan - thanks. Forgot/overlooked that
FWIW, here's the Dell'Orto explanation, in pictures and words:
An old thread http://www.motoscrubs.com/forum/viewtopic.php?f=3&t=1269&p=8628#p8628 might be useful for you. It'sabout a PHBH30, which for me seems a more natural replacement for the VHB29.
gmlaverda
Thanks again for all of this great information. I have been reading here and elsewhere about carbs and came to the conclusion that I should start by changing the idle jet first and second experiment with a larger slide cutaway. My question now would be, how different from my #50 idle jet do I change to? I suppose small steps are in order here, try the next smallest jet first. And if I need a new slide how far should I deviate from my #40? The jets are inexpensive but the slides are not. And seeing the settings for a 250 engine I am wondering how different these settings would vary for a 350.
