Rims and Tires for a Narrow Case
flynbulldog
Re: Rims and Tires for a Narrow Case
Postby flynbulldog » Tue May 01, 2012 10:08 pm
I finally found it and ordered from Hagon. Thanks lacey, hope it doesn't take too long to ship.
blaat!
Postby blaat! » Tue Oct 10, 2017 1:15 pm
Reviving this topic...
Anybody ever measure the width a known set of stock of Mach 1 rims? I recall the OEM parts catalog says something like 18" x 2-1/4" for both front and rear rims. The 2-1/4" doesn't match up exactly to any of the WM standard sizes (WM0, WM1, WM2, etc.), but it must have been a standard size.
2.2" is the outside dimension of a WM0 but that seems too narrow.
2.15" is the inside (tire bead) dimension of a WM3 but that seems too wide.
Anybody know what they were definitively?
Thanks!
Postby Jordan » Wed Oct 11, 2017 10:06 pm
For what it's worth, I have a note that a 2 1/4" rim is equivalent to WM1.
I don't have a source for the info, nor am I certain it's correct.
Are rim manufacturers able to help?
blaat!
Postby blaat! » Thu Oct 12, 2017 10:26 am
Wait, the note is written down? That means it's documented in print. Oh, it's gospel now. Especially since I'm sitting on a set of WM1s that I want to use for just this purpose :lol:
Makes sense. Looking at photos of racers of that period, they used some dang skinny wheels.
Postby Jordan » Thu Oct 12, 2017 2:51 pm
blaat! wrote:Wait, the note is written down? That means it's documented in print. Oh, it's gospel now
That is the opposite of what I said.
KarstenH
Postby KarstenH » Thu Oct 12, 2017 3:11 pm
Hello Jim and Jordan,
i have a link from a german wheel specialist:
http://www.swc-maier.de/wissenswertesfelgen.php
scroll down to the end of the document,
there are the WM sizes explained.
In the table above you see the size of the tire ("Reifengröße" resp. "Reifenbreite") an the size of the rim ("zulässige Felgengröße").
The WM-Sizes are old sizes ...
Also WM1 = 2 1/4 = 1.60
the 2 1/4 isnt a mass that you can find at the rim ...
Karsten
Postby double diamond » Thu Oct 12, 2017 3:19 pm
Jim,
I get 1.675" between the beads on a M. Baruzzo rim from a Mark 3. Ever so slightly wider than a WM1.
CaptonZap
Postby CaptonZap » Fri Oct 13, 2017 3:46 am
And ever so slightly, (.075 inch,) is a ever so slightly under 1/8 inch. ;) Sound about right?
CZ
Postby Jordan » Fri Oct 13, 2017 9:50 am
KarstenH wrote:Also WM1 = 2 1/4 = 1.60
I agree, the 2 1/4 does not seem to mean anything, except that it is "2 1/4".
Postby Bevel bob » Fri Oct 13, 2017 5:36 pm
I have hanging in my garage an alloy rim from an early Manx Norton ,its a 21/4" o/a size, Skinny tires are cool!.
