Can someone please tell me what type of sealing washers should be under the heads of the drain bolts. Mine is fitted with allen headed bolts and steel washers but the leak all of the time.
I am interested in the washers, fibre, aluminium, rubber, copper or whatever should be under the bolt heads.
250 nc fork oil drain plugs
Madman
Re: 250 nc fork oil drain plugs
Rubber: NO
Fiber: (YES)
Aluminum: YES
Copper: YES
I prefer bonded seals (steel/NBR) http://www.potterassoc.com/pdf/bonded_seal_information_and_sizing_chart.pdf. They can be reused several times. I use them on the banjo bolts, the oil filter/drain plug, etc. But i'm afraid they don't sell them for 6mm I.D.
Edit: Just saw you are french. Maybe bonded seals manufactured by german Freudenberg Company are available in your country. Their name is "USIT Ringe"
Fiber: (YES)
Aluminum: YES
Copper: YES
Madman
Thanks, I will look around and see what I can find in this part of France.
Not French, but living here, English father, German mother, I am just a European.
