Hi all,
As the title says, I'm looking to find the size of a few nuts, namely the one that holds the clutch basket in as well as the one holding the gear on the flywheel. Your help is greatly appreciated.
Trying to find Clutch Basket nut size(Monza 250)
halfpast
CaptonZap
Re: Trying to find Clutch Basket nut size(Monza 250)
Do it yourself kit.
https://www.amazon.com/Grip-Thread-Pitc ... read+gauge
http://www.harborfreight.com/6-in-digit ... 62569.html
These two items are indispensable for a serious mechanic.
CZ
CZ
Madman
Do you mean the M16x1 that is in the parts manual? It sits in the clutch basket and is accessed after the clutch stack is removed.
halfpast
Ended up buying a 'large' metric socket set. For the record, the clutch basket nut is a 25mm and the flywheel nut is 30mm.
Madman
As I said M16, but in isometric that means a 24mm spanner.
Users browsing this forum: No registered users and 30 guests
