Identifying a thrust washer
narrow_monza
Postby narrow_monza » Fri Dec 23, 2016 5:56 pm
I'm unable to identify this thrust washer in any NC 250 parts catalog. According to this photo, it's supposed be located behind the clutch drum.
Any pointers?
Re: Identifying a thrust washer
Postby Eldert » Fri Dec 23, 2016 8:10 pm
that is there to line up the clutch with the crankshaft gear .
Postby ducwiz » Fri Dec 23, 2016 8:47 pm
This is washer # 0603.16.055 (20x28x2 mm). In my 250 5speed spares catalog two items are listed, but only one is visible in the exploded draft on page 10. The second acts as a thrust washer, located just behind the main shaft's bearing.
Postby Eldert » Fri Dec 23, 2016 9:17 pm
no 2 mm shims behind the clutch . the larger shim is about 5.5 mm and then a 1 mm or 0.5 mm shim to get things in line . the two 2 mm shims are on the inside of the gearbox .
narrow_monza
Postby narrow_monza » Sat Dec 24, 2016 5:04 pm
Hi Eldert,
I only found the 5mm spacer between the clutch basket and the bearing. I think a washer is not needed in my case since the clutch basket clears the case.
Adriano
