Plastic knop
KarstenH
Plastic knop
Postby KarstenH » Fri Dec 09, 2016 9:49 pm
Hello,
im looking for new distance knobs for my rear shocks.
Has anybody an source or an idea for replacement?
Thank you Karsten
DucRedux
Re: Plastic knop
Postby DucRedux » Fri Dec 09, 2016 11:17 pm
Try finding some small brass rivets (used for knife handles) at an old fashioned or well stocked hardware store. If an approximate size can be located, use the "male" part of the two-part rivet, grind it to a length slightly longer than the thickness of the shroud and peen it into place. This how I effected my own repair.
Re: Plastic knop
Postby Jordan » Fri Dec 09, 2016 11:30 pm
To make new replacements in nylon with a small lathe is super-easy.
Snakeoil
Re: Plastic knop
Postby Snakeoil » Sat Dec 10, 2016 3:33 pm
Jordan wrote:To make new replacements in nylon with a small lathe is super-easy.
Yup, that's what I did on a Japanese set of shocks.
You might be able to find small nylon screws at the hardware store. They are normally in those cardboard drawers in the fastener aisle. You could get a size that would thread into the hole, then just nip off the long end and hit the head with a file until you have the right thickness.
regards,
Rob
KarstenH
Re: Plastic knop
Postby KarstenH » Fri Oct 06, 2017 6:56 pm
Thanks Jordan,
when i would use semitransparent screws instead white it would be perfect.
The remainig head should be not thicker then 1 mm.
Regards Karsten
Users browsing this forum: Google [Bot] and 66 guests
