in this add its is called a Diana Sports
dm250 m1s
Re: dm250 m1s
bikester250
Re: dm250 m1s
Rick,
The only marks on my rims are: Borrani 19x2-Record and Borrani 19x21/4-Record for the front and rear respectively.
The tach and drive I have were purchased a few years after I bought the bike. I'll get a picture or two next week.
For anyone interested here is a link to a group of photos I took to send to Ian Fallon for his latest Ducati singles book:
https://www.dropbox.com/sh/ccdnouc9j06c ... RCSCa?dl=0
Eldert,
Thanks for the lovely photos of the restored bike and the ad!
Phil
Eldert,
Phil
Re: dm250 m1s
The photo Jim posted has some details I haven't seen before- if they're original M1/S parts they show some more parts unique to the M1/S.
I've never seen a Dellorto throttle before, and the top triple clamp has pinch bolts running straight through the clamp with a nut- I don't think I've seen a top clamp like that before.
And the hex driven plugs that screw into the fork legs are threaded for a big nut at the top- both sides, one side lets you remove the tachometer carrier without pulling out the plug- can't tell what the other side is doing.
Re: dm250 m1s
Thanks for the link to the photos Phil.
Looks like yours doesn't have the top triple clamp from Jim's photo- do you know your bike's history?
Re: dm250 m1s
Never mind- Jim's photos were of an SC, not an M1/S.
Re: dm250 m1s
Phil
are your Oldani hubs 36 or 40 hole ?
for the racers Ducati used sometimes bonazzi forks
bikester250
Re: dm250 m1s
Eldert,
These are 36 spoke rims. I think the forks are stock Ducati; when I took them apart to replace seals everything looked like standard Ducati parts.
Rick,
The bike was raced on the east coast by Frank Calder and then passed thru 2 or more owners before I bought it in 1971. Frank raced it with a total loss ignition system (pair of 6 volt dry cells and 2 coils, points with locked in advance).
One of the other owners must have added the stock electrical system. I bought it from a guy who was thinking about making it into a hillclimber (fortunately electric woes persuaded him to sell it). The previous owner had put a Monza head on it (I think because the guides were worn in the original head. I went to the dealer who had traded heads with him and got the original head back.
Electric problem required a new regulator and I added an advance mechanism, later put on the 32mm carb and the exhaust system (the exhaust port had been opened up to 1 3/4" at H&H so the stock pipe wasn't a good fit). Rode it like that off and on for the next 40+ years before doing a complete motor rebuild this past year(all new bearings, new piston/liner, etc).
It's running pretty well- I suspect a Ducati pro could get a few things better than I have but I'm happy with the result.
Many thanks on the rebuild to Nigel Lacey who has provided many parts and put up with tons of questions from me; thanks are also due to members of this forum who have answered questions and provided lots of info. I don't think I could have done this without all of this support.
Phil
Rick,
Phil
Re: dm250 m1s
What or who is H&H ?
Re: dm250 m1s
graeme wrote:What or who is H&H ?
Hi Graeme
H&H stands for Hitch and Haynes
have you ever seen the blueprint for power drawing ? it is made by H&H
they had a Ducati shop long ago
the drawing is in the tech section on Motoscrubs
Re: dm250 m1s
Thanks Eldert
Users browsing this forum: No registered users and 63 guests
