Diana Camshaft and tacho mount
KarstenH
Postby KarstenH » Sat Jun 18, 2016 7:11 pm
Hello,
i restorena 1962 Diana and i want fit a veglia tach.
Has every camshaft a slot for the tacho drive?
Regards Karsten
Re: Diana Camshaft and tacho mount
Postby Eldert » Sun Jun 19, 2016 7:30 am
Hi Karsten
all the original Ducati camshafts i seen so far had slots in them for a tach drive .
KarstenH
Postby KarstenH » Sun Jun 19, 2016 3:42 pm
Hello Eldert,
thank you for your answer.
I will open the head in the next days an tke look at the camshaft.
I hope my camshaft cover/-drive can be mount.
Karsten
Site Admin
Postby JimF » Wed Jun 22, 2016 12:47 am
I think in a recent post (last few months) we established that all the necessary components (tach, tach mounting bracket, cable and tach drive bevel cover) are available, although perhaps not all from the same vendor and not altogether inexpensive either!
halfpast
Postby halfpast » Wed Jun 22, 2016 2:01 am
Yes, I started the thread below regarding adding a tach to my 68 Monza. Like Jim said, it wasn't cheap but I'm happy with the way it turned out. If you have any questions I'll be happy to help.
viewtopic.php?f=3&t=2116&p=16014#p16014
KarstenH
Postby KarstenH » Wed Jun 22, 2016 12:40 pm
Hello Halfpast,
thank you for answer,
i want mount an original veglia tacho - because my diana should look like a Diana Mark3 fourspeed from 1962.
With the little pillbox headlight and the little rear light, small tyres...
It is very hard to find good parts - i have after 5 year ebay membership nearly 90%.
The engine is overhauled by a german specialist but i forgot to give him the tacho drive and now i must mount the drive alone.
I was not shure if the camshaft has the slot for the coupling but Jim says every cam should have this.
Will see next days ...
Karsten
KarstenH
Postby KarstenH » Fri Jul 15, 2016 7:22 pm
Hello,
now i has had a little bit time and now i have a problem.
This is the end of my camshaft - it has no slot for a tacho drive.
Karsten
Postby Jordan » Fri Jul 15, 2016 10:41 pm
Perhaps a special nut, with a tang added could be made? I had an AJS engine that was so modified.
Or, remove the camshaft to machine a slot.
KarstenH
Postby KarstenH » Sat Jul 16, 2016 4:56 pm
Hello Jordan,
do you has a picture from this modification?
I think this i not possible - then is the tacho drive to long.
Karsten
Postby Jordan » Sat Jul 16, 2016 11:10 pm
Something like this nut: http://www.tri-corengland.com/acatalog/ ... _3685.html
- if you can find space for it.
A shortened coupling piece?
Users browsing this forum: Google [Bot] and 75 guests
