I'm about to start a restoration (my first ever) of a 1970 350 Mark3 which is missing its carburetor. I understand the Dellorto VHB 29 AD was fitted at the factory, but is it my only choice? I "think" I want to stay with Dellorto, but are there other models that might work better or are easier to source?
Thanks from a first time poster.
Derek
Carburetor Options / 1970 350 Mark 3
howlndog
Derek
'70 350 Mark 3D
'70 350 Mark 3D
Re: Carburetor Options / 1970 350 Mark 3
just found this copy of an older email on my PC:
I have no personal experience with this modification.
Dellorto PHBHs were used on small block Guzzis, 28mm dia. on V50III and Monza, 30mm dia. on V65 and Lario.
Dell Orto PHBH for a 250 Mark 3
Post by alno » Tue Jun 10, 2014 3:16 am
Hello Chuck,
I have a Mach1 replica with a 350 head (big valves) and big cam & compression with a quite muffler. The jetting I found for the 30mm PHBH is
Main 137
Pilot 45
Air correction jet 100
Needle X22 Leanest position
Atomizer 262P
Slide 3.0
Trumpet 60mm
Nick
28mm Mikuni round slides work very well, I run one on my N/C 350.
Put a Mikuni on it!
howlndog
Thanks Fellas,
I contacted Dellorto UK regarding the PHBH series of carburetors and they recommended this:
http://www.dellorto.co.uk/shop/dellorto-motorcycle-carburettors-parts/complete-carburettors-dellorto-motorcycle-carburettors-parts/phbh-26-to-30mm/r4047-phbh-30as-4-stroke/
My concern with this carb is that adjustments are made from the left (inboard) side. From experience, is this something to worry about, i.e., how much of a a pain in the butt would this be?
Derek
'70 350 Mark 3D
'70 350 Mark 3D
It's not nice to have the adjustments on the wrong side.
Can't they supply a 30AD?
howlndog
Jordan wrote:....Can't they supply a 30AD?
It appears only an "AS" is offered in the PHBH line, no AD. "BD" is also offered
Derek
'70 350 Mark 3D
'70 350 Mark 3D
flanker
It's no issue with mine, I got the cleared float bowl tool, which is pretty cool to see what's happening. Rob
amartina75
Classic Ducati has a NOS VHB29AD listed available for 175.00 GBP
Not really a bad deal considering you shouldn't have to buy any rebuild parts
http://www.classicducati.com/index.php?act=viewProd&productId=773
1966 250 Scrambler
flanker
Barry sells great stuff! +1
JJJ12345
I was in the same predicament. New to Ducati singles, piecing together old and new stuff. I am not a purist, and don't mind trying new stuff. I installed a 26mm PWK Keihin on my 250, and I liked it so much, I installed one on my 350 Sebring. Slight mods to the bolt pattern, but a very clean fit. $115 US dollars. Free shipping. There are a few other threads on this set up. Good luck.
Users browsing this forum: No registered users and 37 guests
