Making room for new project. Long list!
Ian B
Postby Ian B » Thu Dec 10, 2015 2:19 pm
I'm having a clear out of the following singles parts. I'd prefer to post in UK or you can collect from near Lincoln especially the bigger more fragile items like wheels and tank! Make an offer for everything if you like or it's going to get listed on ebay soon.
• Rear Hub drilled for racing
• “ Brake plate
• Sprocket carrier, polished
• Front Hub, 5 rib
• Complete front wheel with 3 rib hub and Borrani Alloy rim
• “ rear “ with 7 rib hub and alloy rim
• 18” Alloy rim
• Mach 1 rear mudguard. Very rough but repairable
• 3 Monza Hex headlight bowls, 1 rough rim
• 130mm headlight bowl
• 150mm headlight rim NEW
• 2 Ignition coils
• 125? Tope yoke, holes drilled in it
• Mach 1 polished top yoke
• 31.5mm fork sliders, polished
• 31.5 mm fork stanchions. NOT standard Ducati, thinner walls, fine thread top nut??? Any ideas what they're for???
• 35mm fork stanchions, very good
• 1 polished crank and rod, no big end
• 1 crank, big end gone
• clutch plates, used
• 2 primary gears
• 1 straight cut primary and clutch basket, racing. 26x64 teeth
• Clutch hub with welded pins
• 250 barrel, gudgeon pin score, no broken fins
• 450 barrel perfect
• White cam
• Green/white cam
• 3 oil pump covers
• 3 oil pumps
• 1 clutch side cover and oval plate
• 2 valve covers
• 2 kickstarts, 1 new chrome 1 poor
• solid rockers and shafts very good
• 12+ shims for above
• 2 33mm 8mm stem valves
• 1 40mm 7mm stem desmo valve
• 1 33mm 8mm stem desmo valve
• Mach 1fuel cap with Agip writing, new chrome
• Gears selector drums, 2x 5 speed, 2x 4 speed
• Various selector forks
• 7 gearbox shafts with gears, various 4 and 5 speed
• bevel tower
• 3 crank bevels
• 2 bottom bevels and housings
• 3 cam bevels
• 2 timing gears
• oil pump gear
• kickstart gear and 2 k/s springs
• Dellorto VHB 25 carb
• Super practic throttle
• Yellow desmo tank, metal with cap, very nice, no decals
• Monza square type tank rough!
• Mark 3 seat, newly covered
• 200 bare head, exhaust flange broken
• Newly powder coated side stand/engine mount
Odds and ends
If you want to make an offer for anything or everything or want photos please get in touch. bracefly@aol.com
Ducati newcomer.. still learning. Treat me as an idiot and you won't go far wrong.
Return to “Classifieds: Ducati Parts/Accessories wanted or for sale”
Users browsing this forum: Harvey and 32 guests
