Hi Graeme
oilpump cover is a Mototrans item . it weights 145 gram less then a Italian cover .
it looks like a 160 cc Monza junior cover but it dont have a steel tube cast into it for the cilinderhead oil feed
selectorbox cover is Monza junior with widecase 5 speed internals .
250 street scrambler
JJJ12345
Re: 250 street scrambler
I see you have a nice 627 Amal. Are you using a manifold or bolting to the spacer? I would like to run one on my 250. Thanks
Sam
Hi
The carb was bolted to the 1/4 rubber spacer and I used a velocity stack to reach the rubber tube , the stack had to be slash cut and positioned at an angle to match up to the filter rubber and also look acceptable. This did give some issues with the setting up of the carb as only the slide aperture was drawing through the filter and not the two pilot circuit outlet holes either side of the slide location slot in the bottom of the carburetter bore.
Sam
Sam
WHA'S LIKE US
DAMN FEW AND THEY'RE A'DEID
Eldert wrote:Hi Sam
i took a picture of the project this morning :
had this bike running about 3 weeks ago . this is how it looks now
That's a handsome bike.
Snakeoil
I'm relatively new here and just read thru this entire thread. All I can say is superb work, Sam. I wish I had the fab tools in my shop that you have in yours. The muffler you made is the stuff I would love to be able to do. Nice to see others doing it.
Bike looks gorgeous. I'm sure it's going to run as good or better than it looks.
regards,
Rob
regards,
Rob
