Just finished rebuilding my 31.5mm Marzocchi's.
One area of concern: one of the outer springs is VERY snug against its fork tube. Is this something I should address?
31.5mm Marzocchi's outer springs
Re: 31.5mm Marzocchi's outer springs
A snug fork spring will wear the outer surface of the fork tube and compromise the sealing surface. Even a properly fitting spring will wear the tube eventually. Internal springs would be an improvement. Matt
amartina75
I haven't had any tight fitting springs like you say. besides wearing your fork tubes you want both springs to be the same. id replace both of them.
1966 250 Scrambler
