Tach on a 250 Monza?
Site Admin
Re: Tach on a 250 Monza?
Postby JimF » Fri Jul 24, 2015 8:00 pm
Could the mechanical drive from a twin be extracted from its bevel cover and installed in a single's cover?
I realize this is no small task, that it would require a competent machinist and some careful preparation...
Postby Rick » Fri Jul 24, 2015 9:22 pm
Eurojamb and Classic Ducati sell everything needed to assemble the tach drive/cover.
Modifying the gearbox cover from a twin to work on a single would be way more trouble than it's worth- the profile is the same around the top and most of the side, but the single unit is shorter. So, after extensive cutting/welding/shaping, the alignment of the camshaft and the tach drive would require line boring through the head, getting the engagement depth right, etc, plus, the twin engine turns 'backwards'- too much work.
Will attach a picture of a single cover on a twin gearbox casting.
Those tach drive covers are on Ebay fairly regularly, or the assembly can be built from new reproduction parts.
Crazygreg
Postby Crazygreg » Thu Aug 06, 2015 2:09 am
Don't forget that most tach drives comes without the little extension piece and oil deflector.. mostly lost over times when disassembled, not possible to use the drive without these parts:
halfpast
Postby halfpast » Thu Aug 06, 2015 4:41 am
Crazygreg wrote:Don't forget that most tach drives comes without the little extension piece and oil deflector.. mostly lost over times when disassembled, not possible to use the drive without these parts:
Good to know, thanks!
Postby Jordan » Thu Aug 06, 2015 8:52 am
I'd call the centre item an Oldham coupling, because it can compensate for shafts that are not in alignment.
