Ducati 160 oversize piston
MayerMR
Postby MayerMR » Fri Jun 05, 2015 7:47 pm
Guys,
I'm working on restoring a n/c 160 Monza and though I have a once-over piston, my machine shop is telling me that the rust from the rings are still causing issues. Does anyone know where I can find a 61.25-61.5mm oversized piston/rings or whether that 175 replacement cylinder liner on Lacey Ducati would work for my 160? I suppose the other option is to look for another cylinder, but ebay is dry right now on 160 parts and there is always a risk with the old stuff like that as well all know!
Lastly, I'm *really* looking hard for a rear brake pedal/spring/shaft. There is one one ebay for about $100 but dang that seems high! Does anyone know if the n/c 250/350 pedal set up would work? Lots more on there and much cheaper!
Thank you!
-Matt
Please visit my new forum for vintage Euro iron; http://www.EuropeanMotorcycleClassics.com. This is a new site and all European marques are welcome! 1971 Ducati 450 R/T, 1965 Ducati 160, 1967 Gilera 106 SS
GT Wunder
Re: Ducati 160 oversize piston
Postby GT Wunder » Sat Jun 06, 2015 1:07 pm
Matt,
I compaired 5 brake pedals ( 3 250's and 2 160's ) and they are all the same, so are the pins.
George T.
MayerMR
Postby MayerMR » Sat Jun 06, 2015 1:16 pm
GT Wunder wrote:Matt,
George T.
George,
Thanks so much! That'll save me a bunch!
Now on to the piston debacle! Any words of wisdom there?
GT Wunder
Postby GT Wunder » Sat Jun 06, 2015 1:31 pm
Matt,
I have a 160 cylinder, but don't have any idea of size/condition. I'll dig it out and clean/measure it.
BTW, my co-workers say I have "old man wisdom" , but I think the "old man" part is more accurate.
George T.
MayerMR
Postby MayerMR » Sat Jun 06, 2015 2:34 pm
George T.
Thanks so much, that would be wonderfully helpful if it's in good shape! Let me know what you'd want for it!
GT Wunder
Postby GT Wunder » Sat Jun 06, 2015 6:00 pm
Matt,
I'm sorry but I don't think the cylinder will do you any good. It measures approx. 61.75 and is pitted in the bore.
George T.
Nick
Postby Nick » Sat Jun 06, 2015 7:17 pm
Tell your machinist to bore the cylinder until it cleans, then send your current piston to a piston maker and tell them to duplicate it in the diameter you specify. The result will be a modern, high-quality piston with high-quality rings. A modern, lighter weight 'slipper' style piston would be ideal. Call up some piston makers and talk to them about it.
I'm running custom-made Venolia pistons in my BSA and Triumph. Called them up, told them what I wanted and the pistons arrived in the mail. If they don't have a blank for your Ducati piston they may want you to send it to them to use as a pattern.
The price wasn't much higher than the dubious off-the-shelf items available from typical suppliers.
Put a Mikuni on it!
MayerMR
Postby MayerMR » Sat Jun 06, 2015 7:33 pm
George T.
Well shucks, I sincerely appreciate the effort though!
-Matt
MayerMR
Postby MayerMR » Sat Jun 06, 2015 7:35 pm
Nick wrote:Tell your machinist to bore the cylinder until it cleans, then send your current piston to a piston maker and tell them to duplicate it in the diameter you specify. The result will be a modern, high-quality piston with high-quality rings. A modern, lighter weight 'slipper' style piston would be ideal. Call up some piston makers and talk to them about it.
Nick,
That's an interesting option and one that I had not considered. I'm coming across most pistons in the $130 range. Is that about the range you were quoted as well?
Thanks!
-Matt
Nick
Postby Nick » Sun Jun 07, 2015 3:15 am
Call them up and talk to them. Tell them what you're doing and what you need. Can't remember the price. And heck, if they can make you a piston why not take your cylinder out as far as is safe, those 160's can use every extra cc you can get!
Put a Mikuni on it!
Users browsing this forum: Google [Bot] and 53 guests
