valve spring compressor
Re: valve spring compressor
Postby Jordan » Wed Nov 05, 2014 10:54 pm
Interesting idea, and welcome.
Can you provide a little more info?
Do you use both tools at once? Dimensions and locations of pins in the bars?
Sam
Postby Sam » Thu Nov 06, 2014 10:41 am
Jordan wrote:Looks good, Sam.
Cheers! works a treat.
WHA'S LIKE US
DAMN FEW AND THEY'RE A'DEID
Sam
Postby Sam » Thu Nov 06, 2014 10:42 am
Recluse wrote:Howdy all, new guy here. I made up a couple of valve spring compressors based off of another post here at Motoscrubs (can't find the thread now...)
They are simply a couple of .25" pins through a piece of 1" x 12" x .25" thick flat stock. Pins are held in by o-rings so they don't fall out and get lost. I had to grind off one corner of each where it interfered with the guide at full compression. To use them you take out the bottom pin, slide the tool through the spring and reinsert the pin. Easy and cheap!
An even more simple solution.
WHA'S LIKE US
Recluse
Postby Recluse » Thu Nov 06, 2014 11:13 pm
Here you go Jordan.
Found the thread that inspired these. The images are gone but if you do a Google Image search for 'ducati single valve spring compressor' it's about the 6th image in.
viewtopic.php?f=3&t=783
Picture helps clarify this a bit...
The pins are located on the front and back edges of the flat bar, maybe .125" in from the edge for strength. The distance between the edges of the pins on the length of the bar should be the diameter of the valve spring. You take out the lower pin, insert the bar into the spring, and reinsert the lower pin, capturing the valve spring between the pins. Then you use the bar as a lever, rotating it towards the valve (clockwise in this case) to compress the spring. When you lever both bars towards each other, you can hold them with one hand while putting in the holder and collets.
Postby Jordan » Thu Nov 06, 2014 11:49 pm
Thanks Recluse.
tobydmv
Postby tobydmv » Fri Nov 14, 2014 10:08 pm
I bought the expensive tool from Eurotrash Spares. Its an amazing piece of kit and worth the extra cutter. Looks exactly like the factory one posted above.
blaat!
Postby blaat! » Fri Oct 15, 2021 3:21 pm
Well I think I figured out an easier and cheaper way to compress valve springs with about $10US worth of items from any hardware store. I used two 1/4-20 (or could be M6) eye bolts and a couple flat plates with a hole in the center cut from a plumbing mounting bracket:
I cut part of the eye away so I could fish it around the lower part of the valve spring. The nice thing is that they hold the valve springs compressed while you put the retainer clips and shim in place. Then just back off the nuts until everything seats in place. The sleeves were only necessary for me as the eye bolts I found were not fully threaded and I couldn't be bothered to go to another store.
Postby Jordan » Fri Oct 15, 2021 8:55 pm
Good.
Users browsing this forum: No registered users and 82 guests
