A couple of questions before the first starting attempt
Re: A couple of questions before the first starting attempt
Postby DewCatTea-Bob » Mon Aug 25, 2014 1:24 am
narrow_monza wrote:Speaking of pistons, is it possible to identify the piston in my bike by reading what's stamped on the top part? I can see some digits/letters through the spark plug hole.
____ Maybe. _ What-all such markings can you see, to be read that way ?
narrow_monza
Postby narrow_monza » Mon Aug 25, 2014 3:14 am
Well, it finally started! Not too bad, a few careful kicks, no kickback ;)
A bit rough when I rev it but that's expected since I still need to do some timing adjustments and check the Amal carb jetting.
Also I think I have an exhaust leak.
Here's a video of the points while it's idling. Is it normal for the points to spark so much?
http://youtu.be/aK2jUCw4czA
-Adrian
Postby DewCatTea-Bob » Mon Aug 25, 2014 7:04 am
[quote= narrow_monza ...
" Is it normal for the points to spark so much? "
____ It seems pretty-much as normal.
I don't have any definite explanation for the occasional flash though. _ Are the contact-faces completely clean of any contaminate ?
narrow_monza
Postby narrow_monza » Mon Aug 25, 2014 5:42 pm
DewCatTea-Bob wrote:[quote= narrow_monza ...
Either I over-oiled the felt block and/or the AAU, or oil is leaking from behind the AAU.
I will clean the traces of oil and check for flashes again.
Users browsing this forum: DBDBrian and 62 guests
