Amal Concentric 26mm, good choice for NC 250?
narrow_monza
Re: Amal Concentric 26mm, good choice for NC 250?
Postby narrow_monza » Fri Aug 01, 2014 4:21 am
I've just measured the inner diameter if the intake manifold and the 2 spacers and they all have an ID of 26mm which matches the Amal 626 I just bought. The carb does have a rubber o-ring sitting in a grove in its flange. Hmm, perhaps I don't need a spacer at all. I also remember seeing asbestos spacers in the past.
-Adrian
Postby DewCatTea-Bob » Fri Aug 01, 2014 12:56 pm
[quote= narrow_monza ...
" I've just measured the inner diameter if the intake manifold "
____ The stock 250Scrambler-manifold (which came with the 27mm-SSI), should have a 27mm-ID !
" and the 2 spacers and they all have an ID of 26mm "
____ That's nicely fortunate but, what-about your Scrambler-cyl.head's 'intake-port' diameter ? ...
If it's also the same dia.size,, then it's NOT of a Scrambler-head, but rather a Monza-head, (of which it's mounting-flange mouth-diameter ought actually measure (a rather narrow) 26.5mm [+/- .15mm] !).
(So that's rather more suited to a member-name of 'narrow_monza', don't you agree ? ;) )
" which matches the Amal 626 I just bought. "
____ What bike-engine did it come from ?
" perhaps I don't need a spacer at all. "
____ That would allow the carb to absorb more engine-heat, which in-turn would warm-up the contained fuel,, and while warm fuel should atomize better, it also ought-to then be less dense. _ So those two effects tend to cancel each other, to varying degrees on engine-performance.
__ As I recall from old mag.articles on the subject,, gas-mileage is increased with the improved vaporization due-to warned-up fuel, while fuel that's rather kept cool as possible increases engine-performance.
So there's not a real final-consensus as to which is best overall, (cool or warmed-up fuel).
But I-myself tend to believe the cold-gasoline is best theory. - (I wonder what Eldert or Harvey think !?)
Curious-Cheers,
Postby DewCatTea-Bob » Fri Aug 01, 2014 1:58 pm
[quote= ducwiz ...
" but why does the Ducati factory add a n/c Monza spacer into a w/c 250 set ? "
____ I must assume that your newer-type gasket-set has been previously opened & robbed, cuz I believe the w-c.set came with at-least two different rubber-spacers with varied IDs for correct fitment on whichever Duke-model.
Besides that, the smaller-ID unit fits both n-c AND w-c 250Monza-models, anyhow !
narrow_monza
Postby narrow_monza » Fri Aug 01, 2014 5:57 pm
DewCatTea-Bob wrote:[quote= narrow_monza ...
+++ Then my cylinder head is probably NOT a scrambler. hmm...
+++ yes originally I thought it was a monza but then I saw the hole where the chain guard mounts, which is a scrambler feature, I think.
+++ Actually it's brand-new out of a box.
+++ I'll probably stick with one of the 2 spacers I have.
Postby DewCatTea-Bob » Fri Aug 01, 2014 9:07 pm
" +++ Then my cylinder head is probably NOT a scrambler. "
____ Another differing-detail between the two head-models, is that Monza-heads have screw-adjuster type rockers.
" +++ yes originally I thought it was a monza but then I saw the hole where the chain guard mounts, which is a scrambler feature, I think. "
____ Yes, those 6mm-holes are-not found on (stock) Monza-motors ! _ (And also, we already realize that your motor has a non-Monza type alternator.)
" +++ Actually it's brand-new out of a box. "
____ That's a nice-find for your Duke-project !
__ So then what motorcycle-engine was it jetted for ?
" +++ I'll probably stick with one of the 2 spacers I have. "
____ Either one will help isolate the carb (& fuel) from cyl.head-heat.
Users browsing this forum: No registered users and 74 guests
