Sprocket Flange Bearing and Spacer
Cam3512
Postby Cam3512 » Sat Dec 28, 2013 10:26 pm
Question regarding the spacer that runs in the sprocket flange bearing (#28). The parts diagram shows it as a seperate piece. Before I try to knock it out of the bearing, is this the case? I want to replace the bearing with a double sealed, and assume I need that spacer that brings the 20mm ID of the bearing down to 15mm.
Cam
atreyu
Re: Sprocket Flange Bearing and Spacer
Postby atreyu » Thu Jan 02, 2014 11:37 pm
Yes that's correct, It's a nice snug fit but it just taps/presses out.
Cam3512
Postby Cam3512 » Fri Jan 03, 2014 1:57 pm
Thanks!
Users browsing this forum: No registered users and 160 guests
