Anyone have a good 160 Monza bottom end to sell?
john jupiter
Postby john jupiter » Sat Nov 16, 2013 9:08 pm
Im located just outside of NYC but do not mind paying shipping.
John
Site Admin
Re: Anyone have a good 160 Monza bottom end to sell?
Postby JimF » Sun Nov 17, 2013 10:10 pm
Try sending an email to Tom Bailey.
I will look for his email address and post it here if and when I find it.
Site Admin
Postby JimF » Tue Nov 19, 2013 7:50 pm
john jupiter
Postby john jupiter » Tue Nov 19, 2013 10:29 pm
Thanks Jim! Just sent him an email.
Postby DewCatTea-Bob » Wed Nov 20, 2013 12:10 am
[quote="john jupiter ...
" Anyone have a good 160 Monza bottom end "
____ I happen to have many of the major parts of a 160 (including complete bottom-end), which I really ought-to part-ways with (since I'm no-longer able to do much of anything with it anyhow). _ But I won't feel like going to the trouble of messing with it any at all unless I feel like I'd appreciate the project that it's intended to become part of. ...
__ Do you already have merely-just a 160 top-end, or otherwise how is it that you desire just a bottom-end ?
john jupiter
Postby john jupiter » Wed Nov 20, 2013 2:07 am
Hi Bob,
Its nothing crazy. I am trying to save 61' 125 sport that needs new crank, bearings, charging system, clutch assembly and timing gears and oil pump.. Other than that its a beauty... . 125cc and 160 monza jr. share the same 52mm stroke, correct me if im wrong but they should work for a proper 125, right? I think the crank in a 160 is stamped 125.1.
Would like to hear your thoughts on this one Bob. And would be happy to pay your asking price if you have a soft spot for 125 Sports.
John
Site Admin
Postby JimF » Wed Nov 20, 2013 2:50 pm
Since we are on the subject of 125s, there is a clean one on eBay albeit in Italy.
281210545430
Thevin
Postby Thevin » Fri Nov 22, 2013 3:02 am
DewCatTea-Bob wrote:[quote="john jupiter ...
The weight of the bottom end is a huge factor/expense,,, I'll be over this weekend and can weight and figure out a crate of sorts and maybe even a shipping cost, if that helps Bob. So maybe with my help we can help John out since it is the beginning of Project season... I know your not a big fan of the 160 anyway....
Vin
Postby DewCatTea-Bob » Sun Nov 24, 2013 1:25 am
[quote= Thevin ...
" I'll be over this weekend and can weight and figure out a crate of sorts and maybe even a shipping cost, "
____ Whoa-Nelly !- (Definition- "a bike, a situation or a person, who has become out of control and gone on ahead".)
__ I'm sorry I've been neglecting to get-back to this thread !
Postby DewCatTea-Bob » Sun Nov 24, 2013 1:59 am
[quote= john jupiter ...
" Its nothing crazy. "
____ Even if so, I could still possibly become drawn-onboard.
" I am trying to save 61' 125 sport that needs new crank, bearings, charging system, clutch assembly and timing gears and oil pump.. "
____ What makes you sure that it needs replacement crankshaft ?
" correct me if im wrong but they should work for a proper 125, right? "
____ I'd figure so but, I've only ever merely seen only-just ONE 125-OHC.Sport model, and have never worked-on any OHC.125-models,, so can't confirm for-sure.
" Would like to hear your thoughts on this one Bob.
if you have a soft spot for 125 Sports. "
____ I do indeed like the 125-Sport (lots-more than the Monza-Jr), however there's more than one reason for why it's likely I won't be a source of a 160 bottom-end for you...
My 160 bottom-end is complete & all-together, so it's not sensible to part-it-out,, and besides, I have TWO 160 top-ends for completing the 160-motor,, and-also, I believe I recall that the motor's top-end was taken-off to discover that the con-rod was loose. _ So the crankshaft likely wouldn't be of any more use to you than the crank you have.
____ It seems to me that ya can find such 160-parts listed on eBay & eBid fairly often enough anyhow. _ For example: http://www.ebay.com/itm/1960s-Ducati-Mo ... a7&vxp=mtr . _ With that motor, you could probably get your Sport road-going considerably sooner. _ (If the seller were to instead part-out that 160-motor, he'd then much-likely get more than just 200-bucks, [although take considerably longer to do so] !)
Have you not been keeping a watch-out for such parts-listings ?
__ Also, I (or someone-else here) could probably relatively easily come-up with most-all of the other parts you're looking for.
