Telesco front fork service for Ducati Mototrans 350 SCR 1974
Rocla
Postby Rocla » Fri Nov 08, 2013 2:29 pm
Does somebody knows the dimensions of the parts (probably made of Teflon) inside the fork? I've found at last the seals (that you can see on the picture) but when I brake, there is shimming inside the fork, and it is not only a seal issue... Who knows the dimensions of these parts inside? It seems impossible to find new ones (I've tried on many Spanish websites thank to a Spanish friend of mine but with no result), so may be, it is possible to rebuilt them?
Re: Telesco front fork service for Ducati Mototrans 350 SCR
Postby Jon Pegler » Fri Nov 08, 2013 2:45 pm
Some of the Telesco forks have a Teflon or nylon bush around the bottom bearing in the forks, affixed to the bottom of the stanchions.
These nylon bushes have to be stretched over the bearing to be fitted.
Size of nylon bush is 37mm outside diametre, 36.25 inside diametre, 14mm wide.
There is also a small ring, a bit like a piston ring, fitted at the bottom of the stanchion.
Size of ring is 37mm outside diametre, 35.5mm inside diametre, 2mm thick.
Rocla
Postby Rocla » Sat Nov 09, 2013 5:41 pm
Hello Jon,
Thank you so much for these pieces of information. If you know where to get such parts, tell me, of course...
Best regards
Pete
Postby Pete » Wed Dec 11, 2013 10:47 pm
You could try Keith Lynas at Ossaplanet http://www.ossaplanet.com/ He was able to help with seals for my Telesco shocks.
Pete
Rocla
Postby Rocla » Sat Dec 14, 2013 10:02 am
Many thanks Pete, I will contact them right now!
Rocla
Postby Rocla » Sun Dec 15, 2013 6:15 am
Unfortunately, Ossa Planet answered me, they don't have such parts, only for OSSA front forks... Telesco was a famous brand with outlets on Spain, UK, France (even for Motobecane bikes), and USA, it is amazing not to find repair kits! I am sure it exists somewhere... :ugeek:
Users browsing this forum: Majestic-12 [Bot] and 87 guests
