Hi guys a question or two.
I have a 1974 450 scrambler/jupiter and am looking for a wiring schematic for it. I have a bunch from on-line and a few from manuals but none seem to be correct to the harness. The harness is oem but is in need of repairs I sure would like a road map. Also what should this bike have 12 volt or 6 volt system? it is also an electronic ignition (non- points) and a red ducati electronica ignition box/coil unit.
Is there a place on this site where schematics are located or I could add what I have? It has been like a black hole so far finding information on this bike even having what was supposed to be the owners manual did not have the right schematic.
74 scrambler 450 wiring schematic
Re: 74 scrambler 450 wiring schematic
6 volt is standard.
The Haynes manual has the wiring diagram for the Ducati Electronica ignition (and the Motoplat)
If you change the regulator for a 12 volt and the bulbs you can run 12 volt if that is what you want to do. The ignition can stay as is.
http://www.motoscrubs.com/Ducati_Electr ... iagram.gif
amartina75
Classic Ducati and Italian Motorbikes sell a new harness for that bike if you are interested.
Here is a link to a picture of the schematic that Italian Motorbikes has
http://www.italian-motorbikes.com/2%20materiale%20elettrico/cablaggio%20scrambler%20elettronico%20schema.jpg
1966 250 Scrambler
Ducvet
Thank you for the replies.
I do have the Italian motorbikes harness but unfortunately for me it is not correct for this bike . In the end I ended stripping the original harness and am replacing wires one by one.
I am glad the bike is 6 volt as that's the only schematics I can find. It is not perfect but I am still forging ahead.
Users browsing this forum: Google [Bot] and 64 guests
