Serious ID Help Needed
Krazymaan
Re: Serious ID Help Needed
Postby Krazymaan » Thu Aug 22, 2013 1:36 pm
Here are a few close up engine shots. Does it appear to be just basic scrambler stuff?
1965 Ducati Scrambler Track Racer
Krazymaan
Postby Krazymaan » Thu Aug 22, 2013 1:43 pm
My front brake drum air intake doesn't seem to be at the same angle as a some of the 65 scramblers and also the speedometer cable angles down hill instead of up hill like some scramblers. Like I say in my title. Im trying to id what i have and what you ducati experts know about the pieces on this bike. Unfortunately the Widow Lady is almost 70 years old now and doesn't really remember much at all. Did these bikes come with different rims or different sized brakes?
Krazymaan
Postby Krazymaan » Thu Aug 22, 2013 1:48 pm
Whats the deal with kickstands. Did they come with dual kickstands or a choice?
Krazymaan
Postby Krazymaan » Thu Aug 22, 2013 1:54 pm
Off topic but... How do i post the full size photos and not these annoying little attachments?
amartina75
Postby amartina75 » Thu Aug 22, 2013 10:45 pm
I see what you mean about the seat cover, it doesn't match the rest of the bike.
Like others have already said I think, you have a 1965 250 Scrambler, that has been modified for dirt track racing.
your handlebars are not from a Ducati, the Ducati ones would not have been suitable for flat track racing.
your front brake plate is normal it just isn't lined up properly, nothing holds it in place before you tighten up the front axle.
your wheels are correct for a 65 scrambler 19" front and rear(changed to 18" rear in 66), the rear dunlop is not stock
the tach looks like a real Veglia could be from a Ducati or just bought at the dealer i am not familar with those, I have seen them sell for $1500 on Ebay (CRAZY)
it's odd you have the tach but no tach drive, the scrambler would not have come with either one, you can find the tach drives for $250 or so
the scrambler did not come with a center stand, only a side stand
your frame has had several things cut off of it to make is more suited for racing
headlight and steering dampner removed
fenders removed and chopped, headlight ears chopped
wiring removed, carb swapped to a 29mm from a 27mm
the previous owner may have done some engine mods but you'd need to open it up and see
hope that cleares up any questions you had
it looks soo clean for sitting as long as it did, I bet you can get it fired up no problem
good luck
1966 250 Scrambler
Krazymaan
Postby Krazymaan » Fri Aug 23, 2013 2:30 am
Yeah, the throttle cable moves like extra thick grease and the slide stays where you let go of the handle grip. I plan on taking care of that on sunday and seeing if it fires up. real gently of course. The oil in this thing had to have come out of one of those old quart cans where you stab the spout into it. Too bad the oil has no value. LOL
Krazymaan
Postby Krazymaan » Fri Aug 23, 2013 2:34 am
I also see my cylinder has been painted Black which tells me that it probably has been off because there is no way anyone could have painted it like that on the bike. So I am very curious about the cam, possible porting and piston myself. Maybe I will have to stick my Milwaukee lighted pencil camera down the spark plug hole and check for stuff. What stuff, I have no idea besides oversize numbers thats if they even did that back then.
Posted Picture-size
Postby DewCatTea-Bob » Fri Aug 23, 2013 9:36 pm
Krazymaan wrote:Off topic but... How do i post the full size photos and not these annoying little attachments?
___ Wouldn't ya know that they just need to be clicked-on once or twice !?
Will that work well enough for you then ?
Postby double diamond » Mon Aug 26, 2013 6:01 pm
Seems to me the scrambles came with a racing kit that included struts to replace the shocks, sprockets? cables? and a tachometer arrangement, though rarely see scramblers with a tach installed. The tach you have is a kit tach although the mounting bracket is not. The kit mounting bracket also attached to the headlight ear, which has been remove on yours. Brazing repair on the front of the tank (where the paint has chipped off) was pretty common; the weld would split along the seam at the font of the tunnel. That plastic clutch lever isn't quite period correct for the 1960's, probably added in the 1970's, so this bike was run for a while. Matt
basketcase
Postby basketcase » Mon Aug 26, 2013 7:29 pm
I am really digging your old flat tracker. My bike is leaning towards becoming a flat tracker too. I might have to copy some mods that your has.
