Hi, did Scramblers (late model wide case) have a bent out kick start lever to clear the pillion peg, or is my Scramblers kick start lever bent?
It's a 450.
Road Desmo and RT's have straight levers.
Bent Scrambler kick start?
Re: Bent Scrambler kick start?
Greame,
I never heard of bent starter levers, but I remember different dimensions for 250/350 and 450 models. The kickstarter of the big thumper is several cm longer, and somewhat larger in diameter. It seems somebody has modified your lever; is it chrome plated?
numbers from the DUCATI parts catalogue:
250/350 - 0400.07.303
450 - 0615.07.300
450 - 0615.07.300
graeme wrote:Hi, did Scramblers (late model wide case) have a bent out kick start lever to clear the pillion peg, or is my Scramblers kick start lever bent?
It's a 450.
Straight, Graeme. The pillion peg folds up out of the way. Plenty of reference photos on Tinternet, but here's a real one
Craig, 450 SCR owner ... with regulation straight kick start lever (see above)
Sorry for the bad pictures but you can see why I asked the question.
The lever just misses the pilion peg. There is a spacer that moves the peg out, so I quess by removing this the peg will move in and the kick lever should miss the peg once I have straightened it.
Thanks for taking the time to answer and posting pictures.
graeme wrote: .. you can see why I asked the question. The lever just misses the pilion peg. There is a spacer that moves the peg out, so I quess by removing this the peg will move in and the kick lever should miss the peg once I have straightened it.
Yeh, classic case of what can happen when a DPO had modified something, but you're not quite sure what. Annoying, but at least there are forums like this to help!
Don't understand why someone would have spacered the pillion peg off the frame ...
