LIKE THE TITLE SAYS, DOES ANYONE HAVE ANY INFO, CLOSE UP PICS OR EXPLODED VIEWS OF THIS CARB. ? i USED TO HAVE A SS1 30 D WITH A STANDARD BOWL (SOLD IT) BUT I JUST BOUGHT THIS ONE AND ITS MISSING A FEW PIECES, DOES ANYONE HAVE A REMOTE FUEL BOWL, CAP, FLOAT, FLOAT PIN, CLAMP/INSULATOR, OR INLET FITTING MAYBE ? i HAVE THE ENTIRE CARB. BUT NONE OF THE FUEL BOWL STUFF. i DO HAVE A STANDARD FLOAT CHAMBER FROM A SS1 29 D SO IF I CANT FIND WHAT I NEED MAYBE I WILL JUST CHANGE IT TO THE STANDARD TYPE CARB...
THANKS, JOE
INFO/PICS SOUGHT ON SSI 30 D WITH REMOTE FUEL BOWL
joe46ho
Too many projects to list...
12 Ducati singles currently
Re: INFO/PICS SOUGHT ON SSI 30 D WITH REMOTE FUEL BOWL
Hi, The remote chamber comes in two sizes, not sure which is right for your 30mm, but i think its the smaller one, its fitted with a rubber lined clamp that mounts on a flat plate which bolts to a slotted bracket that was welded to the frame ,look at fotos of 125/175 racers to see what i mean.The standard angled chamber is no use for this application, I have a new remote assembly but its for the larger sizes 30mm plus??, otherwise i would have fitted it to my 250 , they are better at high revs as they reduce fuel frothing.
Ducati Dude
REMOTE FUEL BOWL Bevel Bob
Bevel bob wrote:Hi, The remote chamber comes in two sizes, not sure which is right for your 30mm, but i think its the smaller one, its fitted with a rubber lined clamp that mounts on a flat plate which bolts to a slotted bracket that was welded to the frame ,look at fotos of 125/175 racers to see what i mean.The standard angled chamber is no use for this application, I have a new remote assembly but its for the larger sizes 30mm plus??, otherwise i would have fitted it to my 250 , they are better at high revs as they reduce fuel frothing.
Hi Bob
Will you please send a pic of big remote bowl
We need for our Americano racy project
Please put dibs on it til we can see pic
Re: INFO/PICS SOUGHT ON SS1 30 D WITH REMOTE FUEL BOWL
where did you read that Bobs remote float bowl is for sale ?
Hi Eldert, the remote float is no use to me as its too big to sit close to the SSi under the frame curve of the NC frame, its a boxed NOS and is complete except for the banjo that goes on the top, i think the purchaser will also need to buy a banjo to fit to the SSi base, these are availiable .I would prefer to swap it for the smaller remote which i think fits SSi's up to 32mm??. No idea what its Value is. But its is for sale.I'm currently working on trying to clean up the richness on small throttle settings, Any idea what the effect of increasing the size of the cross drillings in the needle jet?, Does anyone have the profile measurements of the SSi needle?.Post foto's?? ,thats a laugh, I can only try.
Ducati Dude
Bevel Bob REMOTE FUEL BOWL
Hi Bevel Bob
I called dibs first !
Will you look under pix section for pix of our Americano. (Grazie Bro Jim )
Are you able to send us a pic of your bowl ?
Happy weekend you and yours
Ducati Dude
Hi Bevel Bob
Ducati Dude
Bevel bob wrote:Hi Eldert, the remote float is no use to me as its too big to sit close to the SSi under the frame curve of the NC frame, its a boxed NOS and is complete except for the banjo that goes on the top, i think the purchaser will also need to buy a banjo to fit to the SSi base, these are availiable .I would prefer to swap it for the smaller remote which i think fits SSi's up to 32mm??. No idea what its Value is. But its is for sale.I'm currently working on trying to clean up the richness on small throttle settings, Any idea what the effect of increasing the size of the cross drillings in the needle jet?, Does anyone have the profile measurements of the SSi needle?.Post foto's?? ,thats a laugh, I can only try.
joe46ho
Bob, pm me a price if you can, I didnt realize it was actually for sale... I am working with a guy in spain right now trying to get one, he has a bunch of them, new in the box, 3 different sizes and types i believe (ss1/and ss2) Its hard to say if this will go through or not, but i surely do need one, I have a ss130d with no bowl assembly at all...
Let me know, thanks... Joe
joe46ho
DUDE CHILL OUT ! YOUR KILLIN' ME, AND PISSING PEOPLE OFF ALSO. IF ANYONE CALLED "DIBS" FIRST IT WAS ME. IM THE ONE WHO STARTED THIS THREAD IN THE FIRST PLACE TRYING TO FIND A FUEL BOWL ASSEMBLY TO PURCHASE...
There is an SS1 remote float bowl for sale on e-bay in the UK.
Not cheap though. £100 at the moment (About $160)
Item no 180744847046
No DIBS as yet over here.
I don't want to interfere with international commerce, but I'm sure BevelBob wouldn't want you to be disappointed after the purchase, so, here's a picture of a SSI30A with the SS2 bowl on the left and the SS1 bowl on the right.
To me, the large bowl looks out of proportion with the small bodied carburetor, but that may be just me.
Here's another picture that shows size difference between the large body SSI35 and the small body SSI30.
It's usually hard for me to compare things when I don't see them side by side. If you knew all of this, just disregard and move on.
