QUERY: What is this tool for?
Postby machten » Fri Oct 07, 2011 1:25 pm
A number of months ago I aquired some special tools for Ducati singles. I recognise the most obvious ones and have used a number of them. There is one tool however, that I am not sure what it might be for, so I'm hoping some one can tell me. It is clearly a "home made" tool. Is this perhaps a tool for fitting a kick starter gear spring? Any information would be much appreciated.
Re: QUERY: What is this tool for?
Postby Eldert » Fri Oct 07, 2011 3:12 pm
Hi Kev
it a tool to lock the crankshaft . it should go over the smal gear on the crank that drives the oilpump gear
Postby machten » Fri Oct 07, 2011 3:58 pm
Ah! :idea: Thank you, Eldert.
Postby Jordan » Sat Oct 08, 2011 1:36 am
- Is it indeed a home made tool?
- When would it be used?
Postby Eldert » Sat Oct 08, 2011 7:19 am
the tool could be used to tighten or undo the l.h.treaded nut thats holding the lower bever gear on the crank
Postby machten » Sat Oct 08, 2011 11:10 am
The teeth are pretty well cut, and if was home made, the guy was pretty handy. It's a milled finish, but it hasn't had the same black coloured tempered finishing treatment of some of my other factory tools. On reflection, I guess with this sort of tool you want to ensure that it is sacrificial to the gear when engaged. Following Eldert's identification (thanks again, Eldert) I went scouring through some owners manuals for pictures. I found this pic in the 450 Owners manual, so maybe it is a factory tool, or a least a good reproduction of one. (apologies for the quality - it's probably a scan of a copy of a copy of a...)
