Set the tank and the tail on for a rough idea of the end product.
Rick wrote:if the goal of adding the 2 tubes up to the top tube is to resist twisting/torsion loads on the top tube, they would be more effective if they joined the top tube closer to the outer edges of the tube, instead of going to the bottom center of the top tube- not too likely that a mortal rider would be able to tell the difference though.
Rick wrote:With the swingarm axle area stiffened the swingarm itself will really seem flexible- do you plan to add a hoop beneath the swingarm? A hoop would work better than the plate rib Ducati welded onto some swingarms, but much more work to do.
Rick wrote:Do you plan to convert to taper roller bearings in the headstock?
Eldert wrote:Hi Joe
the seat looks like a airtech item to but for a Bultaco . item nr BULWCS
http://www.airtech-streamlining.com/
joe46ho wrote:One side note Teckhardt, Im not sure if you have ordered your tapered bearing kit from Lacey Eng. yet, but if you are so inclined (have access to a lathe, and some alum. bar stock) and want to save some $$$ I have a brand new kit sitting here and would gladly send you the exact measurements/specs/bearing part #'s etc. This new kit also came with my frame I bought, otherwise I would have fabricated/sourced it myself, but I also have access to a nice lathe, and enjoy using it, some people do not... just a thought... Joe
joe46ho wrote:I recieved a long fiberglass tank with the frame I purchased (of unknown origin) which I had intended not to use and instead mount the Scr tank I have instead. But with this seat pan, it may work out better with the long race tank... Or if I manage to get some extra funds before its gone, Domiracer just took in a late single desmo tank like 1974ish I think ? I really like that tank, and would like to find/buy one, funds permitting...
Users browsing this forum: No registered users and 130 guests
