1959 Bronco 125 VIN Plate
cmborn@tchp.us
Postby cmborn@tchp.us » Sun Jan 16, 2011 2:52 am
Of course my Bronco 125 is missing the front VIN Plate. Can anyone help me with the identifiers? I can figure out where the motor serial number goes but little else. Specifics to the model would be helpful.
Tipo Del Veicolo:
Anno Di Costruz:
No Motore:
No Telaio:
PESO Kg:
CARICO UTILE LEG, Kg.
CILINDR.cm3
Chris
Re: 1959 Bronco 125 VIN Plate
Postby DewCatTea-Bob » Sun Jan 16, 2011 4:50 am
" Can anyone help me with the identifiers? "
Tipo Del Veicolo: = Type/Model of motor-Vehicle = (Motorcycle/Bronco)
Anno Di Costruz: = Year of Construction = (1959)
No Motore: = Motor Number
No Telaio: = Frame Number
PESO Kg: = unloaded Vehicle Weight = (about 95kg/210lbs [certainly under 220lbs!].)
CARICO UTILE LEG, Kg. = Cargo Capacity = (total acceptable load-weight, for riders & petro.)
CILINDR.cm3 = Cylinder Capacity = (actual displacement = 124.4cc - [due to 55.2x52.0 B&S].)
__ That about does it for what I can give you here. _ It took me a bit to recall/work-out what I could, from my several years of working for the Italian co-owners of my Ducati-shop back in the '70s.
DUKE-Cheers,
cmborn@tchp.us
Postby cmborn@tchp.us » Sun Jan 16, 2011 5:57 pm
Thanks so much! Can anyone post a picture?
Chris (on a mission of saving another old duc)
