Hi All,
I have this speedo on my 68 MK3D. I think I now have the right one for it, but what bikes is this right for?
Help Id'ing a Speedo
Re: Help Id'ing a Speedo
" I have this speedo on my 68 MK3D.
but what bikes is this right for? "
____ This model/version is one of the rarest speedo-types,, usually when I've ever seen this fairly common style, it was most always just a 80-MPH version (as for 160-MonzaJr).
I believe this 100-MPH version was originally used mainly on 1966 n-c 250-Monza & many 350-Sebring models, (but not totally positive about it). _ It's been so very long since I've seen totally original Monza & Sebring models that I'm just no longer positive which version -(80 or 100) was originally on which models... I am sure that I've seen (back in the mid-late '60s), the 80MPH-version on some used 250-MONZAs (which all ought not have been old & used enough to have had their original speedo-units replaced!), and most (but not all) used 1966 350-SEBRINGs I've seen had this same 100MPH-version.
__ The white-paint (displaying the number-digits) on the inside of the glass is well known to peel-off inside, and thus leave the viewer to have to estimate the speed which the pointer-needle seems it would mean to indicate, (with the use of whatever speed-numbers are still left showing on the glass).
__ This shown unit has more milage (over 20k!) registered than any other I've ever personally seen on a Duke ! _ (The second highest was my own, with nearly 17-thousand.) _ My own experience with this model/type of speedo has seemed to indicate that they last/run longer than the other model-types of stock speedo-units.
Also, despite the indicated high use, this one appears to still be in pretty-good condition.
__ I've also found that this model-type is fairly accurate at it's indicated-speed
so long as the engine is not overly buzzing-away... Cuz whenever the motor-vibration is moderately-high, the needle-pointer is then buzzed all over the dial ! _ (As is also the case with all other stock model-types of speedo-units.)
Whenever that disconcerting situation is occurring, ya can just pull-in the clutch & shut-down the throttle (to let the revs fall to idle), and then the needle-pointer will quickly settle-down and smoothly indicate your real speed (within about 5%, with a stock front-tire).
____ I'm re-posting the posted pic so that it can now also be completely seen in it's entirety here (without first downloading). _ (I don't even know how others manage to post their pix so that their whole submitted image is not fully displayed.)
DUKE-Cheers,
DUKE-Cheers,
" testing attachment process "
____ I see that now machten... you've now successfully managed to get your picture posted without any portion cut off from it !
" I think I now have the right one for it, "
____ So then how about next posting a picture of your intended replacement speedo-model ?
Thanks Bob.
Yep - as you say, it bounces around a little with a bit of buzzing. I compared its reading with a GPS last week and 62mph is reading as about 75mph, but I haven't explored the drive gear matching yet. (Pity... I was well impressed with the bike's 0-60 performance!
Interesting! I didn't think anything of the milage, having come from a Duc twins background. I guess I'm suprised it's that uncommon.
I've got the correct speedo to test and fit so although I prefer the appearance of this one, if the other speedo tests OK, I'll fit that one and check it against the GPS.
It's the same as this one. I think it's the right one.
Edit: As i said earlier, I prefer the white faced one - looks the part with the white face veglia tacho.
" as you say, it bounces around a little with a bit of buzzing. I compared its reading with a GPS last week and 62mph is reading as about 75mph, "
____ Perhaps your current front-tire is smaller than original ?
Also, it's possible for the vibration-rate to be just-right so as to HOLD the needle-pointer just above or just below that which it actually intends to be pointing towards, so even when you think it's steady, it still possibly pays to kill the engine-revs and then see if the MPH-indication remains the same, (just before ya next begin loosing your set test-run speed).
And when your needle-pointer is getting buzzed-around, of course be sure to do the same, before deciding how far off your meter's true reading actually is. - (I'm sure it's not over 10%, at least compared to the speedometers within the cars I had compared against.)
" I guess I'm suprised it's that uncommon. "
____ Pretty-much all of the junkie speedo-units which came stock on our old DUKEs would break-down one way or another before 13k could be counted onto them !
" I've got the correct speedo to test and fit
if the other speedo tests OK, I'll fit that one and check it against the GPS. "
____ That will be an interesting & welcome revelation to be posted here !
__ I believe the stock speedo-unit for the Mk3 should read 150-MPH, and it's (understandably) even less accurate ! _ (I always thought it was stupid to have them with dials which read over 120!)
____ So how about also posting a picture of your rare -(1968) Mark-3 (non 'D' ?) ?
DUKE-Cheers,
DUKE-Cheers,
____ It seems that my usual slow posting-method has my posts falling out of proper order with your's here Kev.
" It's the same as this one. "
____ I see that now... It does appear to be the correct speedo-model for a w-c Mark-3 ('D' or not).
" I prefer the white faced one "
____ So do I, cuz it's more readable !
You can look-forward to this other type of indicator getting buzzed-around to over-cover even more MPH-range.
__ I see that this particular unit (seen in your last picture) has about 2-thousand less tick-overs than most rack-up before they begin to stop ticking. - (My guess is that this one will likely not make it past the 6k+ average break-down odometer-reading for this model-type. - Sorry to say!)
Good point - I didn't check that and I should know better as I choose to run my 750 Sport with a 90 aspect ratio tyre which affects the speedo a small amount. The tyre looked "right". In retrospect, probably more accurate to say that it didn't look "wrong" enough to attract my attention. I'll check tonight.
It's a "D". I posted in the photos section last week, but I've fixed the "attachment" thing for the singles photos now.
http://www.motoscrubs.com/forum/viewtopic.php?f=11&t=427
I see that this particular unit in your picture has about 2-thousand less tick-overs than most rack-up before they begin to stop ticking. - (My guess is that this one will likely not make it past the 6k+ average break-down milage. - Sorry to say!)
That's not the actual speedo, just a pic I found on the net. I don't have the unit near me and don't remember the odometer reading. Knowing my luck, probably 5,999.
" The tyre looked "right". "
____ The original front tire-size was 2.75 x 18 and (if my memory still serves me at this moment), the outer-diameter of the mounted tire is about 78-inches.
" I tested it on a drill and the needle moved up and down with revs "
____ Likely still under 6k then... Let us know, after you find-out it's milage-reading.
Just a quick update...
The speedo I have reads 13652 on the odo. The tyre is correct, so there is some issue with callibration on the existing speedo. I calibrated drill speed against wheel revoloutions through the drive gear and the replacement tested as close to spot on as i can reasonably expect. +/- 2 %. (Bob, you might have to rethink life time of these things!!! How am I doing if we add up the odo's of working units and average them? Do I get a prize?)
Progress on in situ testing is halted as I went to check and adjust valve shimming and as I was unfamiliar with the condition took the opportunity to remove and dismantle the head. I discovered badly worn opener rockers and cam. Probably due to a previous owner having no idea about valve shimming. Getting a bit off topic now, I know. Just wanted to outline why no progress. I'll come back to this after correcting the top end and testing the speedo in anger.
Users browsing this forum: Google [Bot] and 83 guests
