I have all the parts to fit a valve lifter to a 250 engine but when I offer up the valve cover to the head with the lifter attached it will not tighten down without operating the valve. This is because the lifter pin is already pushing on the rocker (screw adjust) and opening the valve. I have searched the forums and seen Nigel has said there are two pin lengths and I wonder if I have the wrong length or whether I am missing something else. With 5mm of washers on the outside I get clearance but the nut inside does not have all the threads engaged so I am not comfortable with that.
The pin is 7mm long past the circlip and at the moment I am thinking of taking approximately 3mm off and seeing if that works and having less washers outside. Before that I though I'd see if anybody has any other advice (but not about whether or not to fit a lifter to a 250). Many thanks.
Valve lifter
Re: Valve lifter
I do not know the difference, but it would make sense that the pin that bears on the valve may be shorter for the heads with threaded adjuster type rockers. The problem is that the parts books are not very comprehensive and if there is a difference then it may not be listed. Eldert may know if he is lurking, as may Nigel, but he has not posted on here for a while.
paulelana
Re: Valve lifter
Thanks, it is good to know I’m thinking along the right lines,
Re: Valve lifter
Aye Paul,
Nigel has a Facebook account and appears to be posting regularly there. He also has his direct contact details published there. Might I suggest an email requesting guidance, with brief details about your problem? I have always found Nigel very obliging.
Here is his email address: info@bevelsingleparts.com
Good health, BillR
Good health, BillR
Re: Valve lifter
Aye Paul, further to my earlier post and PM, here are some images of the valve lifter fitted to a 1975 350 MKIII engine assembled (!) by MotoTrans.
This engine was originally fitted with the screw and ball rocker arms. You should note that the circlip fitted to the end of the valve lifter plunger is missing and the stroke of the valve lifter plunger is limited by the use of a threaded rod through the front hole of the valve lifter mechanism casting, preventing the full stroke being used. The plunger emerges by 4.8mm from within the lifter body using this setup.
Images 1 and 2 show the offside (RHS) and nearside (LHS) of the external parts of the valve lifter mechanism.
Image 3 shows the lifter in the clear position and image 4 shows the lifter position when depressed to the maximum possible, with the limiting threaded rod in place.
Whether this is as the lifter was assembled at the factory, or not, I do not know? It is as I found it.
Good health, BillR
Good health, BillR
paulelana
Re: Valve lifter
Very interesting pictures. I wondered why there was a hole with nothing in it on the arm as that seemed odd from an engineering point of view. The other thing that is obvious is that the length of the pin past the circling groove is definitely shorter than mine. I’ll take a look at mine this afternoon and see what it all means. Huge thanks.
Roland
Re: Valve lifter
some bolt fits and limits the lift perfect.
(not present here)
(not present here)
350 Scrambler, 1973
paulelana
Re: Valve lifter
Many thanks for all the help especially Bill’s dimensions. I thought I share my experience to add to the knowledge base. With the screw adjusted valves the lifter pin is simply too long and in my case the circling was in a slightly different place to the one Bill measured. This made the pin stick out more but in fact there is no way it would work wherever the circlip is. So off with the circlip. This gives the right clearance. The problem is that the internal spring is then barely compressed and has very little power to pull the pin out. I have therefore added an external spring as per the picture and this supplements the internal one to lift the pin clear of the rocker.
Another both through the lifter body wasn’t required as the way I have it rigged the lever does not go down that far. I wish I could say I planned it that way!
I do have a plate to go under the head bolt and I might try that in the future but for now it works well.
