Club Ducati Scrambler España
kartagines
Postby kartagines » Tue Dec 01, 2009 2:41 am
Hello, .. I have registered as kartagines, .. my gratitude for the initiative in this forum.
I have several single-cylinder, .. 2 Ducatis 24 Hours, 2 Scramblers 250 and 350 cc. and a 350 cc. racer.
I like links of interest to your page for being an essential site in the single-cylinder Ducati in: http://www.ducatiscrambler.es/material.html
Greetings to the forum and I hope to contribute as far as I could something of interest at the same. ;)
I put a picture of my Ducati:
Image Image
Image Image
The Scrambler 250 need restored:
Thevin
Re: Club Ducati Scrambler España
Postby Thevin » Tue Dec 01, 2009 4:14 am
I like # 89 race bike very cool.. and welcome...
Postby JimF » Tue Dec 01, 2009 4:59 am
I am happy that I can enlarge these photos for a better look. The one at the beach (la imagen playa) is beautiful in it's subject and composition. It makes me want to hop on the bike and explore the road in the background. Beautiful bikes, beautiful country. Welcome!
JPALOMO
Postby JPALOMO » Wed Dec 16, 2009 11:39 am
Hola cartagenero:
I will ask you in english then your answer will be available for every body. Do you know that in the 24h there are to points in the distribution gear of the crankshsaft? but wich one is the correct, the index point,"el de la chaveta", or the other one.The problem is that many people knows everyting about the italians Ducati but not the Mototrans Ducati.
JPalomo
Postby DewCatTea-Bob » Wed Dec 16, 2009 3:02 pm
" Do you know that in the 24h there are to points in the distribution gear of the crankshsaft? but wich one is the correct, the index point,"el de la chaveta", or the other one. "
____ I understand this to mean to say: that the bevel-gear on the crankshaft of a 24-Horas model, has not only the normal timing-dot, but also an extra mark as well.
Do I understand that correctly?
If so, please post a close-up picture of that crankshaft-bevelgear.
__ The correct timing-dot ought to be located directly aligned with that 21t bevel-gear's key-slot.
Some models have their crankshaft's bevel-gear with it's timing-dot located at 11-o'clock -(actually @ 11:26-o'clock), for use with camshafts that have their key-slot located in a position that's about -(+/- 5) 8.6-degrees advanced, (compared to other camshaft models). (I really can't explain why Ducati did not make them all the same, [perhaps the change had to do with a common production-error with the alignment of the key-slot?].)
Therefore, the timing-dot/mark that should be used (for alignment with the tower-shaft bevel-gear's timing-dot), depends on the camshaft that's installed.
__ If you are not sure which model of camshaft is installed, then I suggest that you try both settings and learn which alignment produces the most compression or best power.
DUCATIly,
MotoMike
Postby MotoMike » Fri Aug 13, 2010 3:40 am
Duc Singles Admin wrote:I am happy that I can enlarge these photos for a better look. The one at the beach (la imagen playa) is beautiful in it's subject and composition. It makes me want to hop on the bike and explore the road in the background. Beautiful bikes, beautiful country. Welcome!
and there is a girl sunning on the beach :shock:
MotoMike
Postby MotoMike » Fri Aug 13, 2010 3:47 am
Hi kartagines
beautiful pictures of your bikes. I am very envious. I like the road bikes best but they are all very interesting. I notice that they seem to be equiped with amal carbs. I wonder if my 450 might have originally come from Spain. it has an Amal carb and came to me with a Dunstal pipe. what is the front brake on the bike overlooking the beach?
all the best
mike
kartagines
Postby kartagines » Fri Aug 13, 2010 11:39 am
Hi,..is a original Home "Ducati 24 Hours Mototran" only made in Spain in the year 70.
Teckhardt
Postby Teckhardt » Fri Aug 13, 2010 4:33 pm
kartagines wrote:Hi,..is a original Home "Ducati 24 Hours Mototran" only made in Spain in the year 70.
Same front brake on the #89 and #45 race bikes? Looks like a single side twin leading shoe. Similar to an Oldani.
Are they available in Spain. Would make a great upgrade :D
1970 450 SCR
MotoMike
Postby MotoMike » Mon Aug 16, 2010 7:12 pm
thanks
those are beautiful brakes. I bet they haul it down right quick too.
