Mototrans 250 sob story
Kawasakizx9r
Hi, first post (ever). I've owned a mototrans 250 for around five years but haven't seen it for four years due to a so called repairer going bust on me and my bike being put into storage. The head developed a fault so I sourced one for this idiot, I also had him rebore it after supplying a new piston. When I eventually got the bike back the engine top end was in a box, black silicone everywhere, damage to the bike and parts missing. I put the head together last week and got it running yesterday albeit with carb issues and ignition timing issues. It's fitted with a Wassel carb and won't run off choke but I've got the original Amal so I'm going to put that on. I set the ignition timing static to 5 degrees btdc and rotated the points until the test lamp indicated the points were opening but it wasn't happy, I'll have a mess next week, it's too bloody hot in southern Spain right now. Does anybody know where I can source the lock (tab) washers for the cam and crank? Mine are in a very sorry state after the idiot finished with them. Thanks in advance, Mick
Re: Mototrans 250 sob story
Hi Mick,
Sorry to hear of your woes; we have all been there. For your spares, try Recambio Usado, who are in Spain; you can order directly from their web site.
Good luck,
Colin.
Good luck,
Colin.
Kawasakizx9r
Thanks, I use them already but they don't stock the lock washers, looks like I'm making them myself. I've tried loads of places online but drawn a blank. I've just spent a couple of hours working on it and got it running pretty sweet with the original carb but it's difficult to start when hot, I think it's the timing as it's kicking back a bit, it's like trying to kickstart an XL 500! It sounds a bit clattery but others I've heard do also so I'm not overly concerned. The hard work is almost done and I'm determined to save it.
Aye Mick,
The bits you are after, are available and of good quality from Mdina Italia, who now manage Edina and Nigel Lacey's spares business. I have no connection to the business apart from being a satisfied customer. The link to the tab washers is below:
Mdina_Italia_tab_washers_link
Be aware that "tab washers" from other suppliers can be a lucky dip!
Pleased that you have the beast running.
Good health, BillR
Good health, BillR
Hi Mick
tab washers are on Ebay.es seller recambio moto-classica item nr 152887552993
cost 2.50 euro a piece
Kawasakizx9r
Hi all, been very busy but the old girl is running like a new bike, starts first kick most times. She's painted up after sourcing two new side panels and was ready to roll but something told me to check the charging side of things. Yup, she's not giving more than 12.8v so that's my next task. Not a big deal and I'm still keen to get her dead right. I'll put a couple pictures on if I can figure out how to do it later. Ta ta for now, Mick.
Kawasakizx9r
By the way, does anyone know what alternative regulators can be used if I find that's the fault, knowing my luck it won't be but I live in hope, and any info that may be useful on the no charging issue. I know how to test the system but wiring up an alternative regulator etc. Thanks in advance. Mick
mrkprsn
If you use a capacitor you would not have to change anything else on your bike. I use one on a 1962 200GT that is original (6V and points). I just rode it in a Motogiro where we did about 175 miles in one day.
Kawasakizx9r
Hi, thanks for the reply, I've not got a clue what that means but doubt I'll ride that far in a month, never mind a day!
Hi Mick,
Is your bike 6 volt or 12 volt? My two Spanish Ducatis are 12 volt. It is probably easiest to buy a new regulator/ rectifier from Recambio Usado.
Users browsing this forum: No registered users and 120 guests
