175S ignition settings...
Sigean
Postby Sigean » Wed Mar 11, 2026 11:51 am
A little plea for guidance...
After a decade of on-and-off renovation my 1959 175S is up and running! But not running very well.
The engine has a bit of a FrankenDucati style, as the valves are larger than standard for this model and the inlet tract has been opened up by a couple of mm, but other than that so far as I am aware it's in standard form. Starts well, runs well (little bit rattly, but I know the valve clearances need adjustment from their initial setting). But the bike has little "go" about it. It struggles on most hills, its top speed seems limited to about 45mph, and whilst I never assumed superbike performance from its 175cc engine, I had hoped for a little more pep.
Checking the ignition timing with a crankshaft timing disc today, the points open at about 30deg BTDC static. I guess this means the points cam is at 15deg given the gearing of the 4 stroke engine, but this seems a bit high to me (and the points plate is fully retarded). I tried to show a photo - hoping this worked. Suffice to say that when the crank is at TDC the points cam lobe is vertical: might the points pinion be out of true by a tooth...?
Any glassful from the collective pool of knowledge would be welcome.
Sigean
Re: 175S ignition settings...
Postby Eldert » Wed Mar 11, 2026 8:48 pm
Hi Sigean
according to this specsheet the points should open 12/ 15 degrees btdc so i would move the timing pinion 1 or 2 tooth over
and go from there
Regards Eldert
Postby ranton_rambler » Wed Mar 11, 2026 9:04 pm
I run my 1957 175TS at the book setting of 12-15BTDC static. This is at the very end of the slot in the points plate.
I can get about 65mph from it, but about ~50mph is a nice cruising speed. It pays to change down early on hills to keep the engine spinning.
How is yours for starting? Mine will kick back if the ignition is too advanced.
What carburettor settings do you have? I changed to a modern Dellorto PHB and it took a lot of trial and error to get it working nicely. Luckily a 175 can be held at full throttle to get the main jet size without reaching warp speed.
Is the camshaft timing correct? Unless it is all the original parts in the bevel gear train, you can't assume the dots should all line up. I tried a "sports" camshaft and the valve lift measurements told me that the camshaft needed to be 1 tooth away from the dots.
Sigean
Postby Sigean » Thu Mar 12, 2026 9:51 am
Many thanks for these replies. I guess I had just about reached the point of accepting the obvious, that there was an error in my assembly of the ignition timing gear train, and this morning I will open up the timing chest and seek a corrected alignment. I used a new pinion in the timing gears, the one driving the oil pump, as the one in the engine was in poor condition. This new pinion did not have any timing marks, and I copied the pattern of the original, assuming this was correct... Hey ho, life is for learning. But the engine (indeed, the whole bike!) is very much the FrankenDucati as I mentioned in my post. I bought it as (literally, and I do mean literally) a basket** case, seduced by the "Should be no problem, mate, it's all there", so there were bound to be aspects of the build that were going to be problematic... and expensive.
The bike has its original Dellorto 22.5mm carburettor and this seems, now, to be in good condition. Trying to remove the pilot jet ended with me snapping off the end of a steel tap extractor in the jet, which consigned the carburettor to the bin for a while. It being useless at that point, I decided that I had nothing to lose in trying to remove the now blocked and ruined jet. Soooo glad I didn't throw it away, as I found that by very careful use of a Dremel-clone with an abrasive 4mm stone I was able to grind out the blocked jet leaving a little shell of brass threads to pick out of the hole. Magic! Fitted with a new jet (£4.87) the carb is fine.
Off to the shed and my spanners...!
**Actually, chicken feed containers...Image
Sigean
Postby Sigean » Thu Mar 12, 2026 4:38 pm
...and for those hanging on my every word, I altered the position of the contact breaker drive pinion by one tooth, and, judging by the little ride up the local lane, the performance is much more sparking than hitherto. I think the ignition setting is now slightly too advanced - there is the occasional "spit" from the carb. - so a little more fettling is needed, and this can take place once it's stopped raining and I can ride on dry roads. Many thanks for the advice!
Sigean
mrkprsn
Postby mrkprsn » Mon Mar 16, 2026 5:51 pm
Just to add, my 200GT timing is 46 degrees BTDC and my Sebring is 5 degrees BTDC. Both are DC ignition systems. Narrow case Ducs run a wide difference in timing.
