Here is a convoluted tale: when I bought my 250 Mototrans the Speedo was not working, which I traced to the drive gear being worn and not engaging with the ring gear on the hub. I bought a new (pattern) drive gear and a new cable from Nigel, but still no speedo, traced to the cable being a loose fit in the square end of the drive gear.... I had a cable inner made-up by Carrot Cycles with a larger square end and all was well. Fast forward and the cable is again a loose fit in the drive gear and not turning properly.
I have several inner cables and some are a tight fit in the drive gear and some loose, even though they all measure the same (2,6mm) across the flats. Carrot Cycles have retired and I can't find anyone who can make a square end on a cable.... My options seem to be try to find a used, original speedo drive shaft, or maybe see if one of the cable manufacturers can make an inner cable which is a good fit in the drive shaft that I have. I don't see any way of reducing the size of the hole in the shaft.
So, any ideas?
Speedo Cable
Re: Speedo Cable
Try JJ cables .
Re: Speedo Cable
Hi Bob,
Thank you; I knew that I had seen a small firm that makes cables somewhere.
DBDBrian
Re: Speedo Cable
Dave at JJ cables is your man, just made me a one off speedo cable for my Mondial. He has all the various metric fittings.
Brian
Made in England
Made in England
Re: Speedo Cable
This tool makes square cable ends. It looks like it's made to be walloped by a big hammer.
Re: Speedo Cable
That is a hefty bit of kit!
IanHood
Re: Speedo Cable
Colin,
I had the same problem and resolved it simply by shimming the cable end with strips of aluminium cut from a coke can. Somewhat to my surprise, it has lasted very well and was much more cost effective than a custom cable.
Adrian
Re: Speedo Cable
Jordan wrote:This tool makes square cable ends. It looks like it's made to be walloped by a big hammer.
Yep, smack it hard with a lump hammer. Back in the mists of time when I was doing my early riding apprenticeship the little motorcycle shops (Thats all there was) I used to rely on to keep me mobile all had one.
Along with a roll of cable and brass collars and another roll of outer cover and the crimp tool to make the ferrule ends for those as well.
Re: Speedo Cable
As Ian suggested, I have had 'years' of use on a 'small' square end speedo cable by shimming it out with very thin tin can square wrapped around the driven end. Cheers George
Re: Speedo Cable
Thanks for the suggestions, I'll give it a try. What is strange is that the end of the cable that fits into the drive shaft has worn, but the other end that fits into the Speedo is a good fit in the drive shaft, so I wonder what could cause the cable to wear like that? It has obviously been fretting back-and-forth.
Users browsing this forum: No registered users and 135 guests
