Big end
Maurice
Big end
Postby Maurice » Sat Aug 02, 2025 8:34 am
Hello
The ducati 450 (non desmo) has different big end diameters true the years ,mine ducati 450 has serial 455934 ,can anyone tell me what kind of big end i have in mine ducati 450 (i think for end 1972 begin 1973)
Re: Big end
Postby themoudie » Sat Aug 02, 2025 9:11 pm
Aye Maurice,
Some more specific measurements will be required if a remote diagnosis of you 450's big end diameter is required!
Eldert or Nigel Lacey, both are members of the forum, would be the two people to most likely give you chapter and verse. BUT! Knowing Ducati and the many replacement big ends that might be used either by them, or anybody who may have refurbished the crankshaft at some time in it's 50 plus year existance, the only way to actually know what you are dealing with, is to dismantle the crankshaft and measure the components.
DO NOT BE SURPRISED BY WHAT MIGHT BE FOUND! And, if you do not have the correct tools and knowledge, make sure that you get somebody who does, to do the work. My 1974 450 MKIII crankshaft required 28 tonnes pressure in a 30 tonnes press to separate the crankshaft halves! :roll: Any flex in the press set up, can wreck the crankshaft components when dismantling, or assembling. :cry:
I hope that you are succesfull in repairing your crankshaft.
Good health, BillR
Re: Big end
Postby Eldert » Sun Aug 03, 2025 7:18 am
Hi Maurice
only the very first Ducati 450's had a 27 mm bigendpin in the crankshaft halves . and only the very last 450 had a 32 mm pin
engine number 46xxxx and later . so your engine should have a 30 mm pin
Elldert
Maurice
Re: Big end
Postby Maurice » Sun Aug 03, 2025 7:44 am
thanks Eldert
Users browsing this forum: No registered users and 120 guests
