Crankcase breather tube
A.I.M
Postby A.I.M » Sat Mar 22, 2025 10:05 am
Hi folks,
My 250 scrambler engine crankcase breather tube has seriously degraded (full of holes) over approx. 2000 km. I wonder if this might be due to incompatibility with the synthetic lube oil I have been using after the running-in stage?
Has anyone else had a similar problem and found a solution?
I would prefer to continue using synthetic lube oil long-term, it's my belief that it's much better for the engine internals, after running-in on mineral oil.
Al
Re: Crankcase breather tube
Postby Duccout » Sat Mar 22, 2025 10:57 am
Hi Al,
Is the tube rubber or plastic? I doubt that it is due to the engine oil, it is more likely due to the heat and the emissions from the engine.
A.I.M
Postby A.I.M » Sat Mar 22, 2025 1:08 pm
Hi Colin, thanks for the quick reply.
It's the original-style rubber tube with spiral wire reinforcing, connecting the crankcase breather to the inlet air filter.
To my eyes it looked more like the synthetic oil eating into the rubber - BUT - the engine has been suffering from burning a lot of oil, so I guess it is possible that combustion gases have also been getting into the crankcase.
Maybe my best bet is a like-for-like replacement and keep a close eye on it.
Al
Postby themoudie » Sun Mar 23, 2025 12:59 am
Aye A.I.M,
Here is a link to the clear PVC hose that I use as a breather on the 450 MKIII, whilst using Smith & Allan, 15W-50 Fully Synthetic oil, having previously run the engine in using an old school 20W-50 mineral oil, changed at 20, 250 and a 1,000 miles afore filling up with the 15W-50 Fully Synthetic oil.
Clear-unreinforced-pvc-tubing
I have had no apparent "attack" to the structure of the hose in over 14,000 miles of use, over 4 years. Make sure you warm the PVC hose, with boiling water before sliding it over the male crankcase fitting and securing with a Jubilee clip, or hose clamp of suitable diameter. You'll get a shrink fit!
IanHood
Postby IanHood » Sun Mar 23, 2025 11:02 am
Bill,
Do you use that tube with or without the spiral reinforcement inside? I don’t have the reinforcement so wondering how it performs without.
Postby blethermaskite » Sun Mar 23, 2025 11:15 am
Ian, Same as Bill I have been using pvc breather tubing for years with no spiral reinforcement never any issue's.
Cheers, George
A.I.M
Postby A.I.M » Sun Mar 23, 2025 2:21 pm
That's good to know, thanks Bill / Ian / George.
For my scrambler I would like to keep the original "cake-tin" air filter, and the tube connects to the back-side of it. The tube has to bend 90° to fit, and it's only about 35 cm long, so I might try to recover the spring from the old tube and install it in a new one to prevent kinking.
All the best,
Al
Postby themoudie » Sun Mar 23, 2025 9:06 pm
Aye Al, Ian,
To answer your queries about PVC hose collapse. I have never had problems, with the un-reinforced PVC hose collapsing, providing you keep the radius of the curves greater than 45°. However, the bore required for the MKIII's breather is a "standard" size that I cannot remember off hand, but, moulded straight, "T" pieces, "Y" pieces, 90° elbows and blanking plugs are all available from local DIY suppliers, moulded in nylon that resists most of the chemicals they are likely to encounter in an engine breather.
I found that the nylon mesh reinforced PVC tubing had a thicker wall and with the mesh, made it more difficult to bend to even 65° curves. It also seemed to age harden more quickly than the un-reinforced PVC hose. That was down to the PVC polymer mix used in their manufacture.
I hope this helps.
IanHood
Postby IanHood » Sun Mar 23, 2025 10:03 pm
Many thanks Bill.
Postby graeme » Mon Mar 24, 2025 12:30 am
A good auto parts store will have a variety of car heater hoses with various formed bends and sizes. Pick one that has the size and bends you need and cut off the rest.
Just a suggestion,,,
