Advice please
nalimugmug
Advice please
Postby nalimugmug » Sun Dec 08, 2024 2:45 pm
Any suggestions as to how to deal with the bend in this Mach 1 kickstart lever?
Bob
Re: Advice please
Postby Jordan » Sun Dec 08, 2024 9:02 pm
I have reshaped kickstart levers with an oxy-acetylene torch.
Heat the area to glowing, bend, rechrome.
I used the cutting torch head because it provides a wide flame, but do not touch the cutting control.
A torch that uses propane/butane or MAPP fuel doesn't get it hot enough, but maybe one that uses oxygen as well could?
Re: Advice please
Postby blethermaskite » Sun Dec 08, 2024 9:15 pm
Same as Jordan suggests ......but......if you have access or can get access to a hydraulic press? you will still need to heat the lever but not hot enough to destroy or discolour the plating and then press it back into shape while its hot.
nalimugmug
Re: Advice please
Postby nalimugmug » Mon Dec 09, 2024 11:15 am
Thanks for your respective replies.
Having neither a sufficient heat source nor a press, I have asked a local machine/welding shop to assist. Before they commit, I was asked what material is the kickstart made from?
Thanks again
Bob
Re: Advice please
Postby blethermaskite » Mon Dec 09, 2024 11:41 am
Bob, I would be pretty sure its drop forged steel.
nalimugmug
Re: Advice please
Postby nalimugmug » Mon Dec 09, 2024 11:50 am
Thanks, George, ill pass that on.
Take care
Bob
nalimugmug
Re: Advice please
Postby nalimugmug » Thu Jan 16, 2025 12:16 pm
With your help, I've had the lever straightened, a vast improvement. Now off to the platers.
Thanks to all
Here's a link to this guy's website if anybody needs his expertise. Incredible talent-
https://solduramotorsport.com/
Re: Advice please
Postby Duccout » Thu Jan 16, 2025 2:57 pm
Be prepared for a big bill!
