Noob with 450RT
FTWelder
Noob with 450RT
Postby FTWelder » Mon Sep 02, 2024 12:53 am
Greetings!
located in Vermont USA, a few weeks ago I purchased a 450RT Desmo that has been altered a bit. The PO cut some of the frame away to fit a huge square slide carb (supplied) but apparently went back to the original which is connected to the original air cleaner. The coil seems to be original but the wiring is a mess but still connected. A quick compression test went very well. I have a parts book and service manual and would like to hear it run.
My current thought is to fit a familiar (mikuni or OKO) carb and try to restore the electrical system well enough to get a spark and a short ride.
Am I on the right track? I would like to know the actual date of manufacture and can supply the numbers in my next post.
I have a spare frame/swing arm, engine cases and a few other pieces, you can see the shocks have been laid down and are probably smoked.
Thanks for your input.
Frank
Re: Noob with 450RT
Postby Eldert » Mon Sep 02, 2024 6:34 am
Hi Frank
most RT's where build in 1971 . my RT has nr 454444 the the foil sticker on the headstock says 1 /71
the RT uses a AC ignition coil
Re: Noob with 450RT
Postby Jordan » Mon Sep 02, 2024 12:17 pm
Regarding the carby question: I tried several different brands and sizes on my 350.
I found the best was the original factory fitment - Dell'Orto VHB 29 AD, which is likely what you have on yours.
FTWelder
Re: Noob with 450RT
Postby FTWelder » Mon Sep 02, 2024 10:34 pm
Eldert wrote:Hi Frank
Eldert,
Unfortunately the sticker is long gone. Is there an engine number? Ill have more time to search in the coming months. I snapped a photo of the coil still installed in the frame, I have forgotten how to post in forums so Ill add that later.
Jordan wrote:Regarding the carby question: I tried several different brands and sizes on my 350.
They seem to be pretty common and if they work well great!
Re: Noob with 450RT
Postby Eldert » Tue Sep 03, 2024 6:04 am
Hi Frank
the engine number is in front of the barrel on the rh side .
the original ducati coils had a green and red labels . the green label coil is the AC coil .
FTWelder
Re: Noob with 450RT
Postby FTWelder » Wed Sep 04, 2024 12:52 am
Thank you for the help.
The coil has no tag or label any more and the PO removed the points cover and added an external wire from the points to a kill button. It looks like it ran after that because there is some crash damage where the points cover attached, it's a bit messy.
I received a nice MK3 Desmo book from a friend in Italy today and I can feel myself being drawn in. These bikes are gorgeous!
Users browsing this forum: No registered users and 143 guests
