NC 175 Silverstone Timing/Advance.
Kitersteve1964
Postby Kitersteve1964 » Mon Jul 29, 2024 2:32 pm
1960 NC 175 Silverstone with NO additional performance mods
Putting in Electrex World EI.
Going to set with the pulse rotor at Full advance.
What's full advance? The guide says Static 18-21, extent of system advance 28 giving a total advance at 3000rpm ( I presume that's when maximum advance is reached) of 46-49. Setting full advance at 46-49 seems absurdly high?
Last edited by Kitersteve1964 on Mon Jul 29, 2024 3:48 pm, edited 1 time in total.
mrkprsn
Re: NC 175 Silverstone Timing/Advance.
Postby mrkprsn » Mon Jul 29, 2024 3:00 pm
Search for this topic "timing 200gt" There is a lot of good info.
Postby Bevel bob » Mon Jul 29, 2024 8:47 pm
I would go for around 36 degrees with modern fuel that burns faster , and road test ,then add a couple more degrees , if no improvement go back to 36. Easy starting and reduced load on the big end more important than a few mph, Keep revs up to aid oil delivery and no plonking around at low revs.
mrkprsn
Postby mrkprsn » Tue Jul 30, 2024 3:30 pm
It does seem absurdly high but my early 200GT is timed at 46 degrees BTDC (static 18 degrees). It'd retarded as much as I can using the point plate I have. I have driven hundreds of miles with that timing and plan on using that bike in a Motogiro.
Kitersteve1964
Postby Kitersteve1964 » Fri Aug 02, 2024 8:58 am
Thanks everyone. I am going to set at 40. Less than recommended to account for the modern fuel as someone has commented.
mrkprsn
Postby mrkprsn » Fri Aug 02, 2024 12:51 pm
You can also use premium gas which should burn less quickly.
Users browsing this forum: Google [Bot] and 58 guests
