Internal taper spring for front fork
Flyboy767
Postby Flyboy767 » Wed May 01, 2024 10:46 pm
I’m missing the internal taper spring for my front fork. 1965 Diana MK3 with 31.5 mm fork. Any idea where I can buy one? Or the whole internal hydraulic assembly if need be?
It’s item# 515 in the enclosed pic:
1965 MkIII
2009 Monster 1100S
Re: Internal taper spring for front fork
Postby Bevel bob » Thu May 02, 2024 4:57 am
They were missing from my forks too. Bought some from Classic Ducati , but they are not on the web site now, be very carefull with the damper valve at the base of the forks ,expensive and hard to replace.
Flyboy767
Postby Flyboy767 » Thu May 30, 2024 2:08 pm
Thank you for your reply. How do I remove those damper valves? I have a new set of fork legs but I need to move the damper valves over to it. Doesn’t look like there is a lock ring or any mechanical device holding them in place. Is it just a press fit?
Thank you!!
1965 MkIII
2009 Monster 1100S
Postby Bevel bob » Fri May 31, 2024 3:59 am
From memory (not good!) there is an internal circlip thats very difficult to remove, I hacksawed a small cut in the staunchion just enough to get the tip of a scapel blade under the end of the clip. The valve is soft alloy with steel balls that are retained by staking and can fall out. The washer is important and the valve had been replaced upside down in my forks. Parts not availiable .Search the forum for a previous thread.
Postby Bevel bob » Fri May 31, 2024 4:19 am
Look at fork strip post Jan 8th 2018 . Use Junior hacksaw to cut slot but be carefull to cut only into circlip gap otherwise you will destroy clip ,which will be unobtainable . Balls are 5/32 from cycle shop I think.
Postby Bevel bob » Fri May 31, 2024 5:18 am
I am having similar issues with the 31.5 Marzocchi forks on a 175 Motobi Catria Different internals to Ducati.. Sliders worn . not sure what to do.
Postby ranton_rambler » Fri May 31, 2024 6:22 am
I got my clips out with the point of a sharp knife.
Postby ranton_rambler » Fri May 31, 2024 6:23 am
I got my clips out with the point of a sharp knife. I didn’t cut a notch, just pried the clip out.
Flyboy767
Postby Flyboy767 » Fri May 31, 2024 12:12 pm
Ok, I’ll take a look at it today again. I did see the lock clip on the exploded view in the manual but couldn’t really see it in the fork. I can always cut up the fork tubes since they are pretty rusty.
Thanks for all the replies!!!
1965 MkIII
2009 Monster 1100S
