350 Road 3rd gear slipping out
I have covered a few enjoyable miles on the restored 1976 Mototrans 350 Road apart from one problem. Whether changing up into 3rd or changing down into 3rd bike slips out of gear. No problem with other 4 gears so don't think selector is the cause. Before I think about a winter strip down any suggestions of what to look for would be appreciated.
Re: 350 Road 3rd gear slipping out
Suspect rounded dogs on gears 2 & 3 on the output shaft.
Hi George,
From what I've seen on Spanish sites it seems to be a common problem. All is not lost though, there is a simple fix (if you are lucky). Often the cause is wear between the tang of the selector drum and the claw of the shaft from the selector box, which means that the gears are not being pushed into position properly. If you take some shim (as thick as will fit while allowing the parts to fit easily) and bend it around the tang to take out the play, then you may have no more trouble.
I know that this works because I have done it with success. I guess that in the long run the tang can be built up with stellite and ground for a good fit.
Good luck,
Good luck,
Duccout wrote:Hi George,
Good luck,
Hi Colin, thanks for suggestion but I would have thought that I would have trouble with other gears and they are working well.
Hi Jordan, your suggestion sounds feasible. Shame to have to strip engine after recent restoration but I didn't realise how often I used 3rd gear until I couldn't. Going from 2nd straight to 4th is not a good idea in traffic. Owning classic bikes is never easy, at least I can use the Elite, like to ride all year so can expect plenty of cleaning / polishing.
Hi George,
Check your messages, I have sent you a couple of PMs.
Good luck,
Following Colin's (Duccout) advice with regards to 3rd gear slipping out I have shimmed between gear selector drum tang and selector box slot to take up wear and this has cured my problem. Thanks for saving me an unnecessary strip down Colin, PM sent.
A simple solution that might be useful to any other owners of Mototrans widecase motorcycles
Now I can start using it, hoping for a dry summer!
DBDBrian
Well done both, good result, simple things first.
Brian
Brian
Brian
Made in England
Made in England
I agree - a good result, simply achieved.
Good man, Colin
I'm not saying that it will last, but as a temporary fix it can be useful.
