250 Alternator on a 160 Junior
gregwils
Postby gregwils » Tue Jul 04, 2023 9:15 pm
I have a few spare 250 alternators that I am not using at the moment. I was thinking about putting one of them on a 160 Junior, I believe it should fit. The output on the Junior alternator is really low, IIRC it's 24 W. A 40W or 60W 12v system would allow the lights to actually work. Is there any reason this a bad idea?
Greg W
1965 Ducati Monza
1966 Ducati Monza (Project)
1966 Ducati Monza Jr
1986 Porsche 911 Carrera
Pittsburgh, PA USA
Elitepete
Re: 250 Alternator on a 160 Junior
Postby Elitepete » Sat Jul 08, 2023 6:10 pm
Hi all, sorry to junp in on this thread but any information that comes up may be useful. I have a an Elite with the 24 watt alternator and the thought ocurred to me also that a later higher output stator could be fitted, so I obtained a later one with 4 coils and a rectifier regulator for 6 volts which is rated for 200 watts. My problem is that I am not an electrical wizard, but it's obvious to me that there is an ground connection on the 4 coil stator which would not be required when connecting to the rectifier regulator which has the usual 2 connections from the stator. So would it be possible to rewire the stator to provide a suitable output to the rectifier regulator? I don't know if there would be any issues with output phases if rewired?
Postby Bevel bob » Mon Jul 10, 2023 6:28 pm
Hi, I have the 60 watt alternator on a 250. Many years ago I modified it the remove the coil earths and link the coils in a more conventional way and fit a modern rectifier/ control box. This has worked for many years ,however Its possible that there are some benefits with the orriginal and somewhat unusual design. There has been a vast amount of posts in the past about the pro's and cons of the orriginal design, most of which went completely over my head . Perhaps someone could give us a comprehensible conclusion to the saga that would be usefull to us ignorant dimwits.
SubaruPaul
Postby SubaruPaul » Mon Jul 10, 2023 11:48 pm
Probably not the only one thinking it would be great to have Dew Cat Tee Bob back at this moment. I’d guess some archives may assist ?
And I swear I will be getting my 250 and 350 going soon. That’s why I don’t sign in much. But much enjoy a daily check in. Cheers!
