Headlamp shell help
Dave354
Headlamp shell help
Postby Dave354 » Sat May 20, 2023 9:50 am
Hi all, I’m after some advice and wisdom re the headlamp shell I have. It’s been mutilated in a past life, but I hope to get it back to standard looking and function with a bit of surgery!
I am unsure of what size it is? My brain is telling me the diameter should be measured at the headlamp reflector, not the shell or rim?
I’ve attached a couple of photos to assist.
Does anyone know what it’s originally from?
Many thank
Dave
Sebring 350 based Ducati
Triumph Tiger 1200
Cornwall, UK
Dave354
Re: Headlamp shell help
Postby Dave354 » Sat May 20, 2023 9:51 am
Sorry photo cickup
Triumph Tiger 1200
Cornwall, UK
Dave354
Postby Dave354 » Sat May 20, 2023 9:55 am
Triumph Tiger 1200
Cornwall, UK
blaat!
Postby blaat! » Thu May 25, 2023 11:20 am
Looks similar to a Mach 1.
Others may know if Ducati used the same headlight on other models.
Does the hole between the speedo and the mount look production or hand crafted later? That isn't on mine. Also are the depressions next to the switch hole damage or features? Hard to tell from the photos.
Otherwise the size and features look similar
Dave354
Postby Dave354 » Fri May 26, 2023 8:54 pm
Thank you, other than the speedo hole and the cable holes underneath all of the others have been butchered for ignition keys and an ammeter! I’m hoping to get it back to looking like yours!
Triumph Tiger 1200
Cornwall, UK
amartina75
Postby amartina75 » Sat May 27, 2023 1:18 am
Yes the headlight is measured at the lens opening. Looks like yours is a 150mm made by Aprilia. Some Ducati singles came with a 130mm headlight and are more common. If you’re in the states Guzzino has reproductions available. Originals are a little hard to find and expensive.
1966 250 Scrambler
JohnBR
Postby JohnBR » Wed Jun 14, 2023 2:33 pm
I have been fortunate enough to obtain a complete headlamp with all switches from NOS so it should be as close to OEM as possible so any dimensions, photos, you may still need let me know, John
Dave354
Postby Dave354 » Mon Jun 19, 2023 10:04 pm
Hi John, that would be really helpful. It seems there were some variations in design so photos and dimensions would be fabulous.
Dave
Triumph Tiger 1200
Cornwall, UK
Users browsing this forum: Google [Bot] and 76 guests
