Sludge plug
Sludge plug
I am having trouble trying to remove crankshaft sludge plug. Old style with mangled screwdriver slot and preened on threads. Tried cleaning thread with dremel and attempted undoing with windy hammer. Will not budge and just wearing slot. Should I drill it out? I will be having new conrod assembly fitted. Any suggestions would be appreciated
Re: Sludge plug
Excuse the predictive text. Please read peened for preened. Treads mutilated with hammer and punch in plain English
Re: Sludge plug
The last really stuck one I had I drilled a 1/2" hole through it and welded an old ground down ring spanner in the hole.......that got it out!....with no damage
Other, George
Other, George
Re: Sludge plug
Hi George,
So has your big-end just failed? I think other George has the answer - something welded to the plug would be the safest method. Maybe Nigel will see this thread, he must have removed more of these plugs than anyone.
Let us know how you get on.
Re: Sludge plug
Other George
thanks for reply. Have used this method in the past. Drilling large hole seems to help release. I have no access to welding equipment so might have plug removed when engineering company split crankshaft.
Colin, yes big end failed on Elite. Won't know why till stripped, could be blocked oil ways. I should have had big end bearing inspected when rebuilding engine. Life is one big learning curve.
Re: Sludge plug
Hi George
what i do when the slude trap plug wont come out is i drill a medium size hole in it and hammer a Torx bit in there
Dave354
Re: Sludge plug
Hi same here, drill it through and a meaty easy out to turn it?
Dave
Dave
Sebring 350 based Ducati
Triumph Tiger 1200
Cornwall, UK
Triumph Tiger 1200
Cornwall, UK
Re: Sludge plug
George, once you get it out (the sludge trap bung
) get a socket hex plug to replace it with, I am pretty sure Nigel has them, You will probably never need to remove it again.....but it makes fitting an easy and secure job......not that stupid screwdriver slot nonsense
other George
other George
Re: Sludge plug
blethermaskite wrote:George, once you get it out (the sludge trap bung) get a socket hex plug to replace it with, I am pretty sure Nigel has them, You will probably never need to remove it again.....but it makes fitting an easy and secure job......not that stupid screwdriver slot nonsense
other George
Plug arriving tomorrow from Nigel with conrod and gaskets
Re: Sludge plug
It has been a long time since I removed a sludge trap plug on a Ducati. I used an impact wrench, the type that is hit with a heavy hammer, using the largest bit in the kit.
Another idea.
Another idea.
